tranny problem
Old Sep 15, 2006 | 04:50 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
tranny problem
i went to dyno my car last night, and when i start off, i hard a nasty pop noise and the car stop moving, my over drive was gone, but i still have drive and reverse, and 1 and 2, in my 700 r4, i heard a modeul might have gone bad, or a vaccum line, can someone help please thanks chris
Old Sep 15, 2006 | 05:28 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Losing 3rd and 4th is the typical way that they die. No vacuum goes to the trans. The only electronics in the unit are the lock up solenoid and a pressure switch or 2. These do not relate to your problem though. Sounds like rebuild time.
Old Sep 15, 2006 | 05:30 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i think the shift linkage, maybe bent, i think its a 700 r4, im not sure what other tranny that can bolt to a 350 th 350 i think not sure what about that one
Old Sep 15, 2006 | 07:16 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I am not sure what you are trying to say.
Are you asking if the trans you have now is a 700r4?
Or are you asking if a trans other than a 700r4 can be swapped in?
Old Sep 15, 2006 | 07:35 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
its i dont know if its a 700 r4 or the th350, does anyone pictures of both trannys. im hoping the tranny is not going bad, it just sucks not to have overdrive,
but im glad i got the ohter gears
Old Sep 15, 2006 | 08:46 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
get under the car and look at the pan, a th 350 looks like this TCI Aluminum Transmission Pans: TCI-328000 - summitracing.com
a 700r4 looks like this B&M Automatic Transmission Deep Pans: BMM-70289 - summitracing.com
Old Sep 15, 2006 | 08:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you have overdrive, it's a 700R4.
Old Sep 15, 2006 | 09:03 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
yes i have overdrive, so its a 700r4
Old Sep 15, 2006 | 09:08 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i can , drive the car just in drive, and it wont hurt the tranny it shifts fine, i got all gears but overdrive, so i can save to get it rebuilt
Old Sep 15, 2006 | 09:43 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Normally, 3rd soon fails after fourth. If I were you, I would drive it. The end result is a trans swap. You will likely not damage it worse that it already is in regard to rebuild. Keep your triple a card handy though. It could last a mile, or a few hundred miles.
Old Sep 15, 2006 | 09:54 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i think if i drive it normal and not speed i think it will be fine, i checked the fuild and its still good, and i dont have triple a, i drove it for a while today, and its running better then it has been before. i think it will be fine. along as i baby it and not abuse it
Old Sep 19, 2006 | 05:47 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
will the tranny took a ****, its going to cost 600 to 900 to rebuild it
Old Sep 19, 2006 | 10:20 PM
92comaro/conver's Avatar
Car: 92 comaro-rs
Engine: 3.1liter/supercharged350 comingsoon
Transmission: 700R4 trans.
will the pressure switch make the trans gasket leak my trans shifts good /when trans sets over 3 hours it starts leaking at base/dont leak while running /i have a new gasket &pan i just dont know can some one give advice please
Old Sep 20, 2006 | 02:19 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I recommend starting a new thread to help with your pan gasket leak. You may get more info.
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
