84 camaro 700r4- tcc troubles
Car: 84 berlinetta
Transmission: auto
tcc wont engage, am getting trouble code 15. would this be it? just replace coolant sensor? any help appreciated.
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
a code 15 is a low coolant temp at the sensor and yes this will not allow the tcc to lock up, has to be warn and at a certain speed for it to engage. if you know your engine is warm, like from a gauge, could be a bad sensor then
Car: 84 berlinetta
Transmission: auto
changed cts, actually had to change whole neck because it was really stuck.
tcc works but now dies when i put into drive or reverse. got codes 23 and 45. maybe need new tps?? will that make it run rich?
if the ecu doesn't know the engine is up to temp it won't lock the converter up.
