83-92 t-5
Old Sep 20, 2006 | 09:34 PM
ttopformula88's Avatar
Car: 1988 Formula
Axle/Gears: 3.73 Posi
83-92 t-5
Does the 83 t-5 differ from any other years? I have an 88 firebird and just bought an '83 t-5 for it. I was looking at clutches and found that the '83 model years have a different part number for the Centerforce dual friction clutch. Am I missing something here?
Old Sep 21, 2006 | 05:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Can't answer your question, but IIRC, 88-92 T-5's are the so-called world class transmissions, which are a bit stronger than the earlier models, so you may be taking a step backwards with the 83.
JamesC
Old Sep 22, 2006 | 04:16 AM
Pat Hall's Avatar
I'd be willing to bet the part# they listed for the 83 T-5 is different because it's a clutch designed to work with mechanical linkage instead of hydraulic linkage. I also noticed this when I was looking at replacement clutches.
Old Sep 22, 2006 | 01:04 PM
Shagwell's Avatar
Car: projects.......
I thought only the 82's had the mechanical linkage, but I could be wrong...
If it is a v8 trans, then it should have the same input shaft(v6 input shaft spline and length is different), but yes, you would be down-grading to a non-world-class T5, which won't take much power before going BOOM! even the WC's are only rated for something like 250-300ftlbs - hence why GM never put it behind a 350 factory.
Old Sep 22, 2006 | 01:43 PM
83 still had the mechanical crap.
I turfed mine the first time I found a hyd car in the boneyard; must have been around 86 or 87 I did that.
Clutch is the same. I didn't change mine when I changed BHs. Didn't have to. No reason to.
I don't know about GM's "listings" for clutches; they might "list" different part #s for the different years, I don't know. Maybe different spring strengths or something, as far as new cars are concerned. But, they're all the same, as far as fit.
Old Sep 23, 2006 | 12:38 AM
Pat Hall's Avatar
Yeah dimensionally they're both 10.5 inches and 26 spline. I agree that the only thing that might differ slightly between the two is the spring rates in the pressure plates.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
