Anyone with around 300 rwhp still on stock 10 bolt??
Old Oct 1, 2006 | 12:27 AM
streetheatz28's Avatar
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
I was wondering who is still running the stock 10 bolt and has about 300 rwhp. I am planning on replacing my lb9 with a carb'd 355/th350 combo and I was wondering if I HAVE to get a diffrent rear. The car will only be ran on the street so there won't be any hard launches happening. The car is a 86
z28 and has a posi rear, other than that I don't know anything else about it.
Thanks, Charlie
Old Oct 1, 2006 | 12:41 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
See my sig, No official numbers, but I run a ten bolt. I also have sprayed 100shot on my old 350 on this axle.
Old Oct 1, 2006 | 01:43 PM
whiteghost7's Avatar
Car: 92rs
1992 RS w/ Stock 10-bolt with a procharged 350h.o. = 400whp and no problems yet with an eaton posi. I run sticky street tires (BFG KD's ) but they break loose when boost hits so I'v never really shocked the rear. You shouldn't have any problems with 300whp.
Old Oct 1, 2006 | 02:05 PM
LT1FUN's Avatar
500+ HP and 560+ torque at the wheels on my 4th gen LT1. I run Mickey Thompson ET Streets out back every day (they're the only tires I use on the car) and spray 150 off the line. 2800 stall converter. 3.73 gears.
Did so for 5+ years and not one single protest from the 10 bolt. Only mods are an aluminum girdle.
The 10 bolt is the one part on the car which hasn't broke.
Actually, no, that's not entirely true. I did break a few teeth off the 3.42 gears I had at one point. I never even knew I broke them until the day I opened the carrier to install the 3.73's. I was like holy crap! My gears are broken
10 bolts have been given a bad rap and I don't know why. Sure, they're not as strong as a 9" or 12 bolt, but on an automatic equipped car, they can handle a lot of power, even on slicks. I would reccomend a girdle though. They're cheap, easy to install, and do provide additional strength.
You may want to upgrade the axles for even more strength if you want, but it's not a must.
How much power do you expect to be making?
Old Oct 1, 2006 | 03:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
87 TA has a 10bolt with aftermarket posi i believe and girdle. he makes somewhere around 500whp with a 406. and he's running a T56 now, pulled a few 1.5 60 foots. his old auto combo went 1.38
Old Oct 1, 2006 | 06:38 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I was making 400hp on the motor, about 310rwhp.
I have an aluminum girdle and welded my axle tubes.
No breakage yet....
Old Oct 1, 2006 | 07:22 PM
Engine: forged 355
Transmission: th350
I'm not sure how much power it will put out its not going to be a monster just a 355 with a lunati voodoo cam 241/249 .525/546 , heads are the old double humps and the guy i'm buying them from said he had them on a engine that ran 7.0's in the 1/8 so they should be decent. Long tubes, weiand xcererator intake, holley 650 carb. Make not make 300 rwhp but somewhere in that range. I'm still debating on putting headers on the lb9 and getting a supercharger.
Old Oct 1, 2006 | 08:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats a big cam...that motor will want more than 650 cfm carb, and definately want good flowing heads. unless those old double humps are fullly ported, then i'd get somethign else to maximize that combo. that should make well over 300 at the wheels
Old Oct 2, 2006 | 03:50 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
I run about 400 on the wheels with a 97 4th gen rear, 3.42's, aubun pro posi. no problems at all. the only issue i had was the axle on the driver's side was a little warped and i didn't know it. the car i got it from was in a wreck and slammed into a curb... so the axle ate the bearings alive. i was only out about $110 in bearings, all told. I scored a brand new GM axle for free to replace the driver's side. my gears and posi are great, and noise free. I don't even have a girdle yet.
Last edited by flyitlikustolit; Oct 3, 2006 at 04:25 PM. Reason: I'm a retard and can't spell.
Old Oct 3, 2006 | 01:26 PM
Shagwell's Avatar
Car: projects.......
11.72 on mine with 1.6X 60fts, but it's built.
Old Oct 12, 2006 | 02:31 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Old Oct 12, 2006 | 02:33 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Pretty cool.
Thats my motto..
Break it then fix it.
Still running the 9 Bolt, will upgrade when it dies..
Old Oct 12, 2006 | 02:36 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
I made about 150 passes with 60's in the mid 1.6 range before this happened:
Old Oct 13, 2006 | 05:24 PM
slim64's Avatar
Car: 64 Impala, 86 Z28 Camaro, 00 C5 FRC
Sweet vid trevor, nice car too.
I broke my bone stock 10bolt the first time i got on it, that was with around 400rwhp and street tires. I also think that the rear was already on its way out.
If you beef up the 10Bolt there are some great write ups on this forum.
Old Oct 15, 2006 | 03:56 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
First I was running my bone stock 3.42 open 6-cyl rear, then I put in a bone stock 3.23 posi disc rear and still going. I ran the open diff until about 6 months ago and I've had the car for over 10 years. I upgraded to upgrade, not cause it broke though. I'm probably pushing just over 300 to the wheels.
Old Oct 15, 2006 | 11:14 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Thanks, Charlie
There are a few hundred thousand 4th gen LS1 cars with over 300 hp. They all came from the factory with a 10 bolt. They had stronger gears than our old cars, but none the less still the same base axle.
Old Oct 15, 2006 | 11:39 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Ouch Trev, thats gotta hurt.
For your application though you should be fine. Rears typically break when you get sudden traction and all that force is put on everything at once. For street, you'll be fine.
Old Oct 16, 2006 | 02:07 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Over 300Hp on the ground with the auto, so more with the Stick I have now.
Eaton Posi, Richmond 3.73, Welded Tubes, Solid Pinion Spacer, Support girdle with pre-loads, synthetic fluid.
Fine on the street. Launch at 3k with drag radials, snapped an axle.
Replace axle, launch again, snap axle and pinion gear.
Conclusion = 10 bolt fine without slicks.
Going with a 9" so I can launch at 4500rpm like my motor wants to see what my ET will really be.
You can't get enough tractions with street tires to hurt these rears when you have alot of power.
Old Oct 16, 2006 | 02:12 PM
Shagwell's Avatar
1.66 60fts here on 315/35/17 Nitto dr's. - They're still pretty much a street tire. - My 10 bolt is moser axles, Detroit tru-trac, Yukon 3.73, welded tubes, DTS cover with homemade back brace. It'll soon be receiving either a 4.10 or a 4.56, a solid spacer and c-clip elims...when it breaks it'll then receive an invite to the dumpster....
Old Oct 16, 2006 | 02:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
whatevers not broke, part it out! lol
Old Oct 16, 2006 | 02:52 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
after racing about every weekend for the last 4 or 5 years mine finally broke lastnight. i don't know how much horsepower but it ran 13.50's with a stock 10 bolt with 2.73 gears for the last year and a half or so. before that it was just the stock 305 so that probably didn't hurt it any. i was kind of surprised that it lasted as long is it did running low 1.80 60's and the way i drive. i needed more gear and a posi anyways but i was hoping to wait a little longer, at least now i have all winter to fix it.
Old Oct 16, 2006 | 04:43 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you have an auto you are good to go with the 10bolt.
Manuals wreak havoc on the 10bolts.
My old 96 Trans Am M6 with 288RWHP went through 13 rear ends (never broke at the track, just on the street with BFG KDW's), converted to auto with 3600stall and 315/35/17 BFG KD's and it hasn't broken one yet.
I broke my built 10 bolt in my 88 Formula (probably only has 160rhwp).
Old Oct 16, 2006 | 04:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i just dont understand how a manual car running 1.8x 60 foots will do more damage than a auto high stalled car doing 1.6x 60 foots. manual may apply the power force alot quicker to the trans and thus rearend but the auto car is applyin alot more force in general.
Old Oct 16, 2006 | 05:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
The torque converter preloads the axle while a manual transmission gives it a full shock of torque all at once.
Old Oct 16, 2006 | 09:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah still i thought the higher overall power of the quicker 60 foot car would hurt the rear just as much
Old Oct 16, 2006 | 09:54 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
I had an 87 305 TPI auto 2.73's mostly stock that I bought with 113k. At about 120k, I was racing in Philly on 11th when my rear started making a noise. It sounded like a bad u-joint. I raced one more time and it got louder. I made it home and the next day while driving to my friends house to check it out, I blew off a chunk of the pinion. Who knows what the privious owner did to the car, but it was bone stock when I bought it and I always ran street tires. So there's a low power horror story for the old 10 bolt.
Old Oct 17, 2006 | 02:37 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
my old 10 bolt had a used set of 3.73s with an auburn posi and that went my very first run.. wheelhop is a b.i.t.c.h.. that was with a stock torque arm.. on $hitty a$$ kumho street tires.. i have since upgraded my entire rear suspension and drivetrain.. 9" and a g-force t-5 tranny.. no wheelhop anymore and no fear of breaking anything.. your 10 bolt should hold up as long as you have NO WHEELHOP, and a good set of gears and a decent diff.. that was my problem, the used set of gears.. aftermarket axles would be a good investment also.. but they are not entirely needed.. oh ya, one more thing, an aluminum girdle would help the cause..
Old May 22, 2012 | 05:09 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: Anyone with around 300 rwhp still on stock 10 bolt??
how much would I have to upgrade the rear end to make it handle 450ft/lbs of torque from a 383 with a richmond gear 6 speed? Or should I shell out the money for a 12 bolt?
Old May 22, 2012 | 07:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
These axles are un-predictable. I've broken them with stock 305 / 700R-4s, and I've had one survive low-10s on drag radials. That one didn't have any aftermarket upgrades except Richmond 3.73:1 gears and Ratech's best installation kit.
Old May 22, 2012 | 09:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I would not waste money on 10 bolts. I'd try to run the later 28 spline axles and such but dont waste money on aftermarket parts as they wont hold. Just run them til they break and replace it with another stock one until you can afford a 12 bolt or 9". Stick car should use a 9" but seen 12 bolts hold some BIG power. 750whp +
Old May 22, 2012 | 09:19 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
since ive had my car i been through 4 "built" 700r4 transmissions, 2 rear ends( one 9 bolt and one 10 bolt) my current ls1 rear is actually holding up(thanks orr..woot woot) but its only a matter of time, once the t56 swap is complete then make that rear end number 3..... 700r4s and stock 9/10 bolts suck.... thats why i want a t56 and a moser 9 inch...glad its not my daily driver anymore... i can now truly get the parts i want without worrying about having the car the next day...
Old May 23, 2012 | 04:57 PM
3rd one for me's Avatar
Car: 92 RS camaro
Engine: 350 crate 300
love to know how to fix the tach on my 92 RS.
Old May 23, 2012 | 10:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I can repair your tach, pm me if your interested for more details.
BTW to keep it thread specific, im still running my stock ten bolt from 2006 when I posted here last.
SEE sig
Old May 28, 2012 | 06:00 PM
philr85's Avatar
i ran the guts out a my old 83 it had a 358 holley street dominator 850 quadrajet headers cam ect never had any trouble even had it up to 160mph once that was 3:08 gears
Old May 31, 2012 | 01:45 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I ran my 10 bolt with a stud girdle cover, 28 spline axles, and Richmond 3.42's for the last 3 years with around 300 whp, running 1.8 60 fts. Finally broke it at the track this year but I think it was the 1-2 shift that put it over the edge. My 60fts were no faster than last year but I added about 200 rwhp with boost and with slicks shifting 1-2 under boost is I think what did it. Broke half the teeth off the pinion.
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LittleFranks
Aug 20, 2015 03:55 PM
sreZ28
Aug 14, 2015 07:48 PM
