flywheel problem - t5
Old Oct 1, 2006 | 03:31 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
doing the t5 swap, i bought the flywheel for a two pierce rear main seal, wrong one. so i need a 1 pierce flywheel, my question is i see that they have two part numbers, does it matter? one for a mpf and one tbi, which one? i have a 85 camaro witch a one pierce seal motor?
Old Oct 1, 2006 | 03:38 PM
They will both work; but the one for the high-perf motor is lighter than the one for the non-perf one. The difference is about 16 lbs vs 22 lbs.
Get the TPI one, you'll probably like it better. Especially if the car has more gear than it came with.
Old Oct 1, 2006 | 04:10 PM
jayk2k3's Avatar
Car: 85 camaro z28
cool thanx 4 the info. owe u one
Old Oct 1, 2006 | 05:22 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Your 85 has a two pc rear main seal if it is the stock motor that came in the car.
They started 1 pc rear mains in '86. The bolt circles are different between 1 and 2 pc cranks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stangski09
Nov 14, 2015 01:27 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
