6 speed from the firehawks
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
jsut wondering if anyone knows about the 6 speed from the firehawks... i want to know if its the same 6 speed from the 93-96 trans am comeros..
secondly... can i put it in my 92 t/a.... will it fit the stock opening if i got the auto tranny?
third... i know i will need a drive shaft becuase the standard tranny is shorter, but will the tranny bolt up easly? if not what will i have to do to get it in there?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
First, what's a comero?? Second, the 91-92 Firehawks used a ZF6 from the same year Corvettes. That trans is best avoided as its impossible to find the correct bellhousing to fit an f-body. Get yourself a T56 from either a 93-97 F-body or the aftermarket T56 from Tremec. See the tech article on this website for more details.
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
If the tranny is from a Firehawk, shouldnt it already have the correct Bellhousing to fit in an FBody? The Firehawk was/is an FBody right?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If it's a 93-97 Hawk, that uses a standard SBC style bellhousing and is easliy aquired and bolts right to a SBC..
98+ Hawks (and f-body's) have a different bellhousing (not a problem to swap to teh 93-97 style) and the input shaft is longer making the trans harder to retrofit.
ok all this mumbo jumbo.... i want a 6 speed.... what car can i get it out of?... and you making fun of me for saying comero.... grow up
Car: Pair of 92 Z28s
You want a 6 speed(T56) from any of the 93-97 z28s or trans ams...Id also go for a 94-97 and not the 93' but all will work.
If you re-read the above you could have figured this out on your own. Your on a camaro/firebird site, people are gonna give you a hard time about spelling the name right.
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Between Zephyr and Kevin91Z's replies, your question has been well answered. I suggest you read the tech article on Andris' site, T56 6 Speed Conversion for 82-92 F-bodies.
Elephantismo
Feb 13, 2019 12:51 AM
