need help getting out my clutch master
Old Oct 6, 2006 | 10:02 PM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
hey im trying to get out my clutch master cylinder, and i disconected the linkage to the pedal and unbolted the two nuts holding it to the firewal, it still is fighting and not coming out. ive been trying to push the interior side to the engine bay side, is this right?
Joe
Old Oct 8, 2006 | 09:19 PM
anybody?
Old Oct 8, 2006 | 09:22 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
time for the big hammer....
Old Oct 9, 2006 | 06:12 AM
Yes, it is mounted on the engine side of the firewall; and comes off in that direction.
It should come right off, there's nothing holding it on except those 2 nuts.
Try taking off that U-bolt thing, maybe tapt it out of the holes with a piece of wood or something so you don't ding up the ends of the threads.
Be aware though, that if it's hard to get apart now, you will invent a whole new vocabulary trying to get it back in. I'd suggest figuring out what's holding it stuck. I'd suspect that maybe you should loosen the pedal pivot bolt, that holds the other end of those 2 brackets that are also under those 2 nuts you've taken out.
Fireslash
Apr 11, 2016 06:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
