Over Drive vs. Drive
Old May 31, 2006 | 02:15 AM
Beachmonkey6's Avatar
Car: '88 GTA
Engine: L98 -350TPI
What is the difference between overdrive and just Drive?
Old May 31, 2006 | 02:17 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
the overdrive gear. if on the highway use overdrive. if racing keep it in D
Old May 31, 2006 | 06:04 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The gear ratio od drive is 1:1
The gear ratio of overdrive is .70:1
Old May 31, 2006 | 06:47 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Around town or low speed limits, just use "3" because anything under 40 mph in "OD" shifts into "3". Use "OD" for speeds over 40 MPH.
Old May 31, 2006 | 09:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
With the gear selector in Drive there's also an overrun clutch that provides engine braking.
Old May 31, 2006 | 08:43 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
To make things incredibly easy.... OD allows for 4th gear to engage. D limits the transmission to 3rd gear.
As above, D provides engine braking and is thus better if you happen to live in the mountains and don't like changing your brakes every other weekend. Or if you somehow managed to get a hitch on your thirdgen to haul the house around.
90% of drivers should just put it in OD and drive.
Benefits of D? More instantly available acceleration, engine braking.
Benefits of OD? Improved fuel economy, smoother ride.
Old Oct 3, 2006 | 12:52 AM
Car: '88 GTA
Engine: L98 -350TPI
So im guessing its not ok to switch from OD to D while driving or vice versa? Or is it?
Old Oct 3, 2006 | 01:11 AM
xpndbl3's Avatar
Car: 1984 Z28
no reason technically to switch back and forth while driving, not to mention the downshift is bad since the line pressure is not up during the shift...so leave it in place and keep it there basically
Old Oct 3, 2006 | 01:19 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
well from my once you go messing around withy thew gear selector . things start wereing out faster!,..,.,why you folks say just drive around in od? cause if i did that my rpm's would run higher right thus using more fuel? i mean why not just put in drive and go? right? i mean they are automatic overdrives right?
also does anyone know at what point the auto drive should kick in?or when?
Old Oct 3, 2006 | 01:21 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Most roads around this town are 35mph roads. This allows me to hit 40 mph, go into OD and damn near idle around town assuming no traffic. When should I use D, 2, and 1? If I am in stop and go traffic on city streets should I keep in in D?
Old Oct 5, 2006 | 12:10 PM
xbcrguy182x's Avatar
Another thought...is it safe to shift from 1 to 2, 2 to 3, etc while the car is moving?
Old Oct 5, 2006 | 03:25 PM
DJP87Z28's Avatar
YES...you can up & down shift the gears as long as you are in the RPM ranfe for that gear. It is a manual tranny without the clutch. Just don't do anything stupid when shifting.
Old Oct 6, 2006 | 12:06 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
By "RPM range for that gear" do you mean "between idle and redline"?
Old Oct 6, 2006 | 06:41 AM
DJP87Z28's Avatar
YES......
Old Oct 6, 2006 | 10:30 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Well its different for me. I always drive in "D" if I'm going under 40 mph. But I swapped my gear in the rear form a 2.73 to a 3.73. If I left in "OD" it would shift into overdrive (4th gear) at a lower speed. And thats hard on the tranny. My speedometer says I'm going 40 mph....but im only going 25mph.
I like staying in "D", and I like to down shift 3-2-1, sometimes I upshift myself too.
Old Oct 6, 2006 | 03:57 PM
Car: '88 GTA
Engine: L98 -350TPI
Ok so say your driving in D and you quickly decide that you need to jump onto the highway, what do you do if cant shift into OD? Do you have to pull over, stop the car and then switch the gears from D to OD?
Old Oct 6, 2006 | 05:16 PM
DJP87Z28's Avatar
Ok so say your driving in D and you quickly decide that you need to jump onto the highway, what do you do?
Floor it, downshift to 2nd is automatic.
Old Oct 6, 2006 | 05:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
DJP just meant "don't do something stupid like shifting down into first gear on the highway going 65mph". That's not a safe speed for that gear. If you're going below 20mph you can choose any forward gear, and it won't hurt anything. If you're in 2nd and on the highway, you'll notice your redlining to keep up to traffic, so shift up! These are so easy we let our ladies drive with an auto trans, like, c'mon!
Old Oct 6, 2006 | 07:26 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I think they are saying it is safe to shift from D to OD while driving along no matter what gear you are in. Right?
Old Oct 6, 2006 | 08:02 PM
DJP87Z28's Avatar
With some of these Post about driving a Automatic my opinion they better go and take driving 101. If they can't understand a 4-sp auto they will go crazy with a 5-sp auto.
Old Oct 8, 2006 | 10:57 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I hate driving in OD. It always shifts into fourth and locks up the convertor at inappropriate times (the base of a hill for instance) I just leave it in Drive untill I hit the highway, where I pop it into OD.
Old Oct 8, 2006 | 11:38 PM
Car: '88 GTA
Engine: L98 -350TPI
Toehead. So your saying that it is ok to pop it into OD while driving? -I dont have to stop the car first? And this is ok without a shift kit and all?
Old Oct 8, 2006 | 11:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Good lord beach monkey, how old are you? Yes, you can shift it while you're moving, who taught you to drive??
Old Oct 9, 2006 | 09:10 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Yeah....if im driving in "D" and hit the Highway, after Im around 80, then maybe ill stick in "OD" But hell yeah its ok to shift "D" to "OD"
But if you have it in "R" make sure you stop the car befor going into "D"!!
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
