Rear Diff Griddle
Old Oct 11, 2006 | 10:03 AM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
Rear Diff Griddle
I am thinking about getting a rear diff griddle. I have an 89 RS. I recently put and eaton posi and 3.73's in there and i was interested in that diff cover with the bearing compressing bolts. I was wondering if anyone has installed them, and how easy they are to install and what is a good brand?
Old Oct 11, 2006 | 10:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Piece of cake. I used Summit.
https://www.thirdgen.org/forums/atta...-89-guides.jpg
JamesC
Old Oct 11, 2006 | 01:35 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's easy enough to do but you may want to weld your axle tubes also. Theres a few tech articals on building up your rear end.
Old Oct 11, 2006 | 02:08 PM
FastEddiesIROC's Avatar
Alot of people have told me to weld my axle tubes, but isnt the center of the rear cast iron and the tubes steel?
Old Oct 11, 2006 | 02:36 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
There is a Group Purchase on MAC products through FASTTOYS.NET
Check out the GP board it ends this FRIDAY the 13
The regular Price for there diff cover is $129 But it's cheaper in the GP Message me for the price. If we post the prices publicly we won't get the discount. It's cheaper than the SUMMIT one.
Old Oct 11, 2006 | 03:02 PM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
Do they make rear end girdle for the Austrailian rear end in my 88 Formula 350? Or just for the 7.5".
Old Oct 11, 2006 | 03:23 PM
JamesC's Avatar
There are a couple of articles in the tech section on beefing up the 10-bolt.
Brian, check the following link:
Rear End Girdles
JamesC
Old Oct 14, 2006 | 01:29 AM
Pat Hall's Avatar
T/A Performance just started manufacturing the nine bolt girdles not too long ago. They're the only company making one for the nine bolt. For the original poster, sorry, I can't resist. Are you going to use that "griddle" for pancakes or waffles?
Old Oct 15, 2006 | 08:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
haha, Pat, you beat me to it
I have the summit one as well. It was $139, so that group purchase sounds pretty good, assuming it has similar specs (1/2" thick, sturdy aluminum, etc)
Little tip - don't bother using a gasket, it'll just leak. Use a bead of RTV. Make sure you don't tighten those preload studs too much, just a teeny bit of preload. They come into their own once the rear tries to flex.
I think you're right on the center section being cast iron, compared to steel tubes. I welded my tubes, but didn't do a very good job. You can use a stick welder, and some "weld all" rods, or high nickel cast iron welding rods to do it. I think I just used E6013 rods, and did a pretty **** poor job of it. When people say "oh yea it's only held on with two measly spot welds", I have to wonder if those people have ever seen those two "measly" spot welds. They're HUGE. I welded it as a feel good thing.
oh, you can also get main caps studs to strengthen your rear end. All these things do not require disassembly. The most crucial part of beefing a rear IMHO is the solid pinion spacer, which does require disassembly.
Old Oct 15, 2006 | 11:18 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Don't weld your axle tubes to the carrier. It weakens the metal and creates a stress riser. Also, since our cars have a torque arm the axle tubes only carry torque during braking. In other words, no chance of twisting an axle tube during a launch.
Old Oct 15, 2006 | 11:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Can you run over that one for me? That doesn't sound right..?
Orr89RocZ
Oct 7, 2015 12:47 PM
draco
Oct 4, 2015 09:25 PM
LittleFranks
Sep 17, 2015 12:22 PM
E Rod
Aug 28, 2015 05:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
