Help?700R to B&M 350 conversion kit who has done this
Old Oct 11, 2006 | 05:27 PM
rebstew187's Avatar
I used a B&M conversion kit what i was needing to know is what's the deal with the torque arm rubber.my factory stuff doesn't line up and it say in the directions to order a part from GM and use that but it looks like the same thing I already have.it is a two peice rubber mount andthe rubber is on one bracket and the bracket is welded to another bracket.both are this way.tech line told me I had to drill out teh spot welds and use just the rubber and do away with the spot welded peice.if I do away with the spot welded peice what will hold the other side on?I'm I looking at this wrong?if I order the GM part it says will it all work?like I said I know it says to order another part but the part it is telling me to order looks like what I have in my hand.just the pics screwed up?
Old Oct 13, 2006 | 01:40 PM
rebstew187's Avatar
anyone?dealer now says the part # I need is discontinued.Whats the deal?
Old Oct 16, 2006 | 02:36 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
conversion
Hey man, I'd check another dealer, I just did the conversion last week. The 700R4 outer bracket will not work, you'll have to find the other one, I believe that they are the ones on the 200 transmissions. you get the rubber for the inside of the mount from the piece that bolts directly to the tailshaft of the 700. The kit comes with bolts to attatch the rubber piece to the new inner mount. Hope that this helps. let me know if you have any more questions.
Mickeyruder
Sep 2, 2015 02:45 PM
lt1z350
Aug 28, 2015 05:57 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
crazynights
Aug 21, 2015 06:53 AM
