Light weight Flywheel for 91 350ci
Old Oct 16, 2006 | 06:25 PM
silverdragon87's Avatar
Car: 1987 Convertible Z28
Engine: 305TPI
Transmission: BW-T56
Axle/Gears: 3.42:1
I have a 91 Z28 that I am going to do a minor buildup on. I am planning on eventually getting a ZZ4 385 Fastburn. I would like to do a lightweight Flywheel but am not sure what works the best. Now to complicated things I"m not sure what trany I will have. As it looks now I may have a WC T5 at first and then eventually get a TKO 600. I also have a T56 in my other car but at this time I do not plan to remove it. Any Suggestions would be greatly appreciated. THANKS!!!
Old Oct 22, 2006 | 04:55 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
It kind of depends on what torque and rearend gearing you have. I have a 19lb on my 400 and with the 4.10 gear and 3.27 first gear of the tremec, its no problem.
Old Oct 23, 2006 | 06:12 AM
Pat Hall's Avatar
The same flywheel will work for the T-5 or the TKO. You'd only need a different one if you went with a T-56 instead. Fidanza makes a really nice lightweight flywheel, but they're quite spendy (about $300). You can get GM lightweight one for about half that cost or less.
Old Oct 23, 2006 | 01:49 PM
Engine: 305TPI
Axle/Gears: 3.42:1
I currently have plans to run a 3.42 rear with about 425HP. I'm not even sure what the stock flywheel weight is, but I do think I want a single piece flywheel. I'll look around for the Fidanza and see what I can find. Thanks!
Old Oct 24, 2006 | 12:37 AM
Pat Hall's Avatar
The factory GM lightweight flywheel is approximately 16 lbs. IIRC. The standard one is about double that. The lightweight one should work fine with 3.42 gears since that's what the 305, 5 speed Z/28 cars had for rear gears with the light flywheel.
Old Oct 25, 2006 | 05:14 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I'm curious, why are you all asking what gears he has or plans to use? I didn't know it mattered, but what happens if he has the wrong gears?
Also, is this a significant mod (measurable freed up hp, increased traps), or is this one of those Airfoil-type, "scraping the bottom of the mod barrel for that extra .10" mods? No sarcasm intended, I genuinely want to know.
Old Oct 26, 2006 | 05:44 AM
Pat Hall's Avatar
The advantage of the lightweight flywheel falls under the same theory as the advantage of an aluminum driveshaft. Less rotational weight means the motor spools up quicker. But you do need to have steep enough rearend gears and a light enough car to take advantage of this. If you have a really heavy car and not enough rearend gearing, a heavier flywheel helps you get all that weight moving easier when you drop the hammer. I'm running a 30 lb. Hays billet steel flywheel in my 69 Camaro, but I don't have to worry about it hurting the drivetrain too much from shock loading since I'm running a beefy Muncie 4 speed and a stout 12 bolt rear in that car. With a factory T-5 trans and the puny 7.5" ten bolt rear, a lot of shock loading on the drivetrain can be pretty destructive to the trans and rearend.
Old Oct 26, 2006 | 06:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm running a GM light-weight flywheel with a 1LE alum drive shaft and 3.23's. No problems, though you have to learn to drive a bit differently, or at least I did (the lighter weight flywheel slows more quickly which is noticeable between shifts).
JamesC
Old Oct 26, 2006 | 12:26 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I installed a Fidanza flywheel with a Sachs clutch over the summer. I've run 4 autocross events and an open track day since installing it. I'm very happy with it.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
lt1z350
Aug 23, 2015 08:33 PM
Omega
Aug 10, 2015 12:46 PM
