speedo drive gear same for 3.08 and 2.73?
Old Oct 20, 2006 | 11:49 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Should I be able to swap the driven gears for the speedos for a 2.73 rear end that was put in place of the original 3.08, without swapping drive gears? I can pull the drive and driven gears from an existing f-car with 2.73 if I need to but taking both tailshafts out may not be worth the effort for the 10% or so the speedo is off.
For confirmation that I've got the correct drive gears while I'm there, can I verify which drive gear is in the tailshaft once I pull the driven gear? Been a while since I was there.
Old Oct 21, 2006 | 02:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
do this and if everything works out then yes
Old Oct 22, 2006 | 09:45 AM
naf's Avatar
naf
The drive gears were the same (red) and were easily visible through the driven gear port. So no worries.
Old Oct 23, 2006 | 06:47 AM
Pat Hall's Avatar
Just for future reference, all ratios 3.23 and numerically lower use the red, 17 tooth drive gear. It changes to the gray, 15 tooth gear for 3.42 and numerically higher gears.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
knight72
Aug 10, 2015 09:32 PM
beachrodder
Aug 7, 2015 04:27 PM
