Help with rear end gears
Old Oct 20, 2006 | 09:32 PM
TransamSBC's Avatar
Car: 1991 TransAm
Engine: 1969 360 sbc
Transmission: th350
Axle/Gears: posi 4.11 gear
Ok first of here is what i have done to the car it is a 1991 Trans am that i took out the tbi 305 and put in a 1969 350 small block i got it bored .060 over i have a 510 lift cam at 234 at 50thos i put on a holly intake and put on a 600 cfm edlbrook carb also have a high output hei coil and headmen header s with 3" flowmasters . but here is what i would like to know when i take off it is kinda slow off the line but has very good power up in rpms i would like to know what kind of gearing i should use for the rearend. thanks eric
1991 Pontiac Trans Am - Eric's Pontiac "The Night Rida"
Old Oct 20, 2006 | 10:03 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
OK first you need to get a stall converter like 3500 rpms and put that in and then you should get like a good posi rear like 3.73 or 4.11 gears man that thing will rip and of course some good tires because with all that power you're gonna spin them like crazy and maybe a helmet too in case you wreck
I hate run-on sentences, don't you!
Old Oct 20, 2006 | 10:43 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Another reason might be that the power off the line is kinda slow, depends on what kind of intake it is. Single or dual plane. Usually the dual planes generate all the power from around 2000 and up rpms.
Like Lo-tec said, 3.73s willl be fine, and if you dont have a stall converter, well it'll definately help, but im suprised you're not having issues with your power brakes with all the vacumn the cam is sucking up.
Old Oct 20, 2006 | 10:52 PM
TransamSBC's Avatar
Car: 1991 TransAm
Transmission: th350
ok i was told to get a 2800 stall would that be good but yea i think i am goin with a 4.11 is that all good.
Old Oct 20, 2006 | 10:57 PM
Car: 91 Camaro RS
Engine: Small Block
what kind of cam do you have with .510 lift and 234 @.050 I'm just kind of curious which brand it is. I have a .507, .510 with 240, 246 @.050. A 3000 stall converter works just fine for me. I use 3.73 gears in the rear and at 60 mph my rpms are about 2500 with 26 inch tires.
Old Oct 21, 2006 | 02:48 AM
TransamSBC's Avatar
Car: 1991 TransAm
Transmission: th350
The cam is made by comp cams and the set up u said sounds good. One question is the way u have it good for street.
Old Oct 21, 2006 | 01:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
2800-3200 stall would be about right, but I wouldn't use a 4.11 gear. Thats just too much IMO. You'll just run out of gear too fast... 3.73 would be a much better idea.
Old Oct 21, 2006 | 01:47 PM
TransamSBC's Avatar
Car: 1991 TransAm
Transmission: th350
What would be a good site to buy the gear form anyone know of one..
Old Oct 21, 2006 | 02:17 PM
Lo-tec's Avatar
Summit racing, Jegs, or Randy's Ring and Pinion are a few to look at.
Old Oct 21, 2006 | 02:59 PM
Car: 91 Camaro RS
Engine: Small Block
Summit and Jeg's are right there by you in Ohio. So it would also get there pretty fast.
Old Oct 22, 2006 | 01:23 AM
Air_Adam's Avatar
Or you could even just visit them, and drive home with it.
Old Oct 23, 2006 | 03:44 AM
TransamSBC's Avatar
Car: 1991 TransAm
Transmission: th350
ok first off how is the 3:73 on the freeway what are the rpms like at about 75 80 with OD
Also does anyone have a 3:73 gear they would like to sell!!!!
Old Oct 23, 2006 | 05:42 PM
Car: 91 Camaro RS
Engine: Small Block
they arent too bad on the freeway at all and i dont even have OD
Old Oct 23, 2006 | 07:16 PM
Air_Adam's Avatar
They are not bad at all on the highway... should be around 3000 w/o overdrive... overdrive will be a good bit lower.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
