t-56 help
Old Oct 21, 2006 | 08:22 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
t-56 help
Ok. finally got my t-56 clutch to work. Had the fork installed incorrectly. My question is....It work great, but grinds if I push the pedal all the way down. Ive done tons of searching and found no exact matches...I have 3rd gen pedals. Im looking for a cheap solution if possible...
Old Oct 22, 2006 | 08:33 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I'am imagining your clutch peddle is sticking way past your break peddle so your getting a lot of throw at the moment, you might want to try my adjustable master cylinder mod, worked great on mine, here is a link
https://www.thirdgen.org/forums/tran...ghlight=master
Old Oct 22, 2006 | 10:26 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
did this eliminate the grinding?? you are right my brake pedal sticks out about 2" or so past the brake pedal...
Old Oct 22, 2006 | 06:27 PM
Tony89GTA's Avatar
Car: 89 GTA
Yes cause now your not over extending the throw of the clutch.
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
'91 Formula
Nov 25, 2001 04:58 PM
