I need help finding a clutch
Old Oct 29, 2006 | 06:50 PM
big_red_dre's Avatar
Car: 84 V6 camaro & 92 saturn SL2
Engine: 2.8L V6 for now
Transmission: t-5 5 speed
Axle/Gears: Stock
Hey guys i have a 1984 v6 berlinetta and the 2.8 thats in it just aint gonna cut it. ive lookin around and pricing all the parts im goin to need to put in a v8 my only problem is that i dont knkow what clutch and flywheel combo im goin to need to run. I plan on rebuilding a stock 350 with a larger cam and possibly roller rockers can anyone let me know what i need.
Old Oct 30, 2006 | 06:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What tranny is going to be used?
The normal off the shelf flywheel and clutch for an '84 camaro with a 5 speed should work fine, but that V-6 tranny won't work with your V-8. I assumed you're going to get a V-8 T-5 to match the new V8, then obviously, my first sentence in this paragraph makes sense
Old Oct 31, 2006 | 08:04 PM
Axle/Gears: Stock
actually i was hoping that i could use the tranny that i have and get a clutch that will work with the 350. is that possible or is my v6 t5 tranny not strong enough
Old Oct 31, 2006 | 09:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
ooh, ooh, I finally get to use this;
This is what it's like, trying to use a V6 tranny with a V8. Wrong hole spacing.
Old Nov 2, 2006 | 06:30 PM
Axle/Gears: Stock
well i call the tech line at summit they told me that its not a matter of bolt paterns because all flywheel bolts are at 60 degree intervals. he said what it come down to is whether or not my input shaft is long enough to work with the v8 bell housing
Old Nov 6, 2006 | 03:07 AM
Pat Hall's Avatar
Ummm actually the V6 input shaft is about 1/4" too long. If you read through some of the older posts on here about putting a V6 T5 behind a V8, some people ended up cutting that much off the pilot area at the end of the input shaft. The only other challenge is finding a clutch disc that's big enough diameter for a V8 with a 14 spline hub instead of 26.
Drone358
Sep 1, 2015 02:50 PM
Drone358
Aug 27, 2015 11:15 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
