best trans for me
Old Nov 1, 2006 | 09:58 PM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
best trans for me
Hey guy's this is what im looking for, I need a trans that I can still race BUT can drive city and highway. I have a turbo350 but it sucks large ***** driving highway. I was thinking about 700r4 but I don’t know how good they are for racing. Is there an auto trans that has 5 gears
Old Nov 1, 2006 | 10:34 PM
Demon355's Avatar
If you want 5 gears might as well get a manual. Good for racing and putting around town.
Old Nov 1, 2006 | 10:47 PM
Engine: 87 LG4 305
i would love one but i dont have the time right now for that, i just need something good for racing and good for highway or city
Old Nov 2, 2006 | 02:45 PM
Shagwell's Avatar
Car: projects.......
There are plenty of guys running 700r4's in race applications, many running well into the 10's. - If you do a little searching you'll find what you need for how much power. - PATC has a very good "tip sheet" with the ins and outs of the 700r4. - It is a great street/strip trans.
The 200r is another option, but will usually cost a bit more overall. NOT the 200c, the 200r4(how many 9 sec GN's have you seen? Most are still running their 200r.)
Old Nov 2, 2006 | 05:50 PM
Engine: 87 LG4 305
i was thinging about adding an eletric overdrive to my turbo350, when i race i could turn it off and when im on the street its on, would that work?
Old Nov 3, 2006 | 01:47 PM
Shagwell's Avatar
The Gear Vendors type OD add-on units would require A LOT of work to fit under our cars. The torque arm would have to be custom, custom short drive shaft, cutting and widening of the trans tunnel to fit it under the car....etc. All at the cost(probably more than) a decent 700r4, which will bolt in.
Plus, you still wouldn't have that 3.06 low gear of the 700....
Old Nov 5, 2006 | 08:39 PM
Engine: 87 LG4 305
is there any 700r4 that you can shift yourself, not just a full auto
Old Nov 5, 2006 | 08:54 PM
RacerDad916's Avatar
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
I have built a number of 700's that went in 500hp plus cars that weighed less than 3000lbs. They do Ok, the sun gear shell is usually the weak link. There are kits and complete valve bodys available with a manual, forward shift pattern. If you are making ALOt of hp, the 3-4 clutch pack(atleast) will need freshened over the winter. You will need to start with an '87 or newer 700(not a 4L60E) to get the good 10 vane pump, good sprag and good low gear planetaries. If you have someone build it, use the vette second gear servo assy, Kevlar band and Raybestos 3-4 clutches. I will run a 700 behind my 383 as a daily driver. Hope this helps.....
Billy
Old Nov 5, 2006 | 09:04 PM
Engine: 87 LG4 305
Billy
do you have any idea where i can find one of those good 700r4. i didnt know that they had one that you could shift
Old Nov 5, 2006 | 09:07 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The transgo 700 2&3 kit has a full manual shift option.
Old Nov 5, 2006 | 09:32 PM
Engine: 87 LG4 305
what about 700R4.COM - Bowtie Overdrives. do they make good trans
Old Nov 5, 2006 | 09:41 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I don't know. I build my own transmissions. Run a search for opinions on Bow Tie Overdrives. They have been around a long time and they also have a nice website.
Old Nov 6, 2006 | 01:31 PM
Shagwell's Avatar
yes, you can get a full-manual valvebody for a 700r, you can now even get a manual vb with a trans brake. - I agree, you'll want a later(87 or newer) unit. Depending on the dollars you're looking to spend and either you abilities to either biuld one yourself or having one built locally, ordering one built for performance applications can be the best way to go. Many joe-schmo trans shops don't have the knowledge to build a good hipo 700r4. The old T350/T400 tricks don't work with a 700. - Personally I reccomend PATC(raptor), but Dana at Pro Built is also highly reccomended on this board, and from what I've seen/heard, he builds a good trans and runs a good company.
also, there are several people putting more than 500hp at them and in cars heavier than 3000lbs that are running 700r's with no issues. - I've got one in a big block powered truck caring the front end through low gear that gets driven to and from the track, and back and forth to work(over 30 miles oneway) 2-3 times a week.
Old Nov 6, 2006 | 02:45 PM
Engine: 87 LG4 305
who is raptor and dana?
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
