T56 Pedals
Old Nov 7, 2006 | 05:15 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
T56 Pedals
Well I already bought a set of thirdgen pedals for my T56 swap. Now I am reading that with these pedals the clutch will sit 3 inches higher than the brake pedal and that the clutch engagement is at the top of the throw. To correct this people had relocated the connection rod on the clutch pedal. My question is where does this need to be moved to in order to correct the problem. Closer or farther from the firewall or toward or away from the clutch pivot point? I would like to modify this but don't want the master cylinder to bind.
I also see that McLeod sells and adjustable master cylinder for the T56. Has anyone used this? If so, what did you think? Does McLeod sell the whole hydraulic assembly or just the master cylinder? I don't know if I want to get it if it is just the master cylinder because I hear it is a real pain to bleed.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
ironbmt
Sep 27, 2015 06:00 AM
