V6 auto. and V8 T-5?
Old Nov 11, 2006 | 05:33 PM
AtomicZebra's Avatar
Okay, here's my situation. I found a member that is willing to trade my complete auto setup for his complete T-5 setup. The problem is my setup is a 2.8l and 3.1l both with automatics. His setup is a v8 with a T-5. First off, will these interchange? I asked my buddy, and he said that the T-5 won't work and that I dont have a 700-R4. (News to me, I could've sworn that I have one) So, if I don't have a 700-R4, what do I have? I was also planning on buying a B&M Mega Shifter, which if I don't have a 700-R4 means this shifter won't work, right? Can someone please help me? I guess I should've done more research.
Old Nov 11, 2006 | 08:34 PM
Nobody has an answer? Well can somebody please at least tell me what kind of transmission came in an automatic 88 2.8l Camaro or an automatic 92 3.1l Camaro? Can I at least use the B&M Mega Shifter with my car? Thanks.
Old Nov 11, 2006 | 09:44 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
do a search in the V6 Boards for specifics but no they wont interchange. V6s used in camaros/Firebirds use what GM calls there small bolt pattern, V8s use what GM calls there Large bolt pattern. the small bolt pattern looks kinda like a triangle, and the large bolt pattern looks kinda like a half circle.
Old Nov 11, 2006 | 11:16 PM
Alright, thank you for replying.
Old Nov 14, 2006 | 02:36 AM
Pat Hall's Avatar
The B&M Megashifter should work with your application. You do in fact have a 700r4, but it's completely different from the V8 700r4. The shifter should work on either trans though. Oh yeah, a V8 T5 won't work with a 6 cylinder either, but it's way easy to locate 6 cylinder T5's. The V8 ones are a lot harder to come by.
The White Knight
Nov 24, 2007 11:54 PM
fbodman
Nov 29, 2005 12:37 PM
85ws6TA
Jan 26, 2001 03:55 PM
