86 Camaro detent cable ?????
Old Nov 13, 2006 | 11:22 PM
HEAVYMETAL's Avatar
Do I have to remove the transmission pan to install a new detent cable on my 86 Camaro
Old Nov 14, 2006 | 02:19 AM
Pat Hall's Avatar
It's not necessary to remove the pan. The end of the cable at the trans end hooks into an eyelet coming out from the trans. It's a little tricky getting the new cable hooked into the eyelet, but with a litte patience you'll get it hooked up eventually. There's one 10mm bolt that holds the cable in the trans. Undo that bolt and you can lift the cable assembly far enough out of the trans to disconnect it from the eyelet.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
