i need ur help on tranny leak
Old Nov 15, 2006 | 01:17 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i have the stock tranny its the tr700r4 think thats the one that comes with it but its the tr tranny....anyways i have two bolts that are stripped and just spin when tighten them... i tryed switching bolts around and the hole is stripped anybody know the size of the hole so i can tap it? is that the easiest way to fix it?
Old Nov 15, 2006 | 01:18 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
m8 1.25
Old Nov 15, 2006 | 01:24 PM
A tap won't do any good, if the threads are stripped out of the hole. Kind of hard to cut new threads in metal that's not there any more.
You'll need to Heli-Coil the holes.
Old Nov 15, 2006 | 04:09 PM
Engine: 355
i was told i can tap the 5/16 hole to a 3/8 hole to make it work is that possible? whats a heli coil and where do i buy that at?
Old Nov 15, 2006 | 05:12 PM
Engine: 355
i got all the things to tap it to 3/8 will it work?? anybody
Old Nov 15, 2006 | 05:47 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
It will work. If memory serves, the tap will go right in.
Old Nov 16, 2006 | 01:08 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What holes?
If its the trans pan bolts, they make oversize self tapping screws in the Help section.
Gets u a couple oddball bolts, but it works quite well.
I would personally helicoil it, but some people arent machanical in nature so the Help stuff would still be a valid fix.
later
Jeremy
Old Nov 16, 2006 | 01:24 PM
Engine: 355
Originally Posted by 3.8TransAM
What holes?
later
Jeremy
i fixed it this morning i used a little bit longer bolt and put a nut on the bolt cause it reached threw and screwed into the nut much easier then tapping...
Mark_ZZ3
May 24, 2018 01:02 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
