Good 700r4 rebuild kit? Manual valve body?
Car: 88 GTA
Axle/Gears: 3.27 9bolt
What is a good rebuild kit for the 700r4? I dont want to expensive but I dont was junk, something to hold a very rough driver and 350rwhp
Also are there any manual valve bodys out there for the 700r4's?
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
700s aren't good performance transmissions the gear ratios aren't optimum for racing and they just don't hold up well in high HP applications you would be better off with a TH-350 or 400 conversion in a car that is to be driven "rough" the 700 is more for mileage with the O/D and low 1st gear ..
Go to http://www.700r4l60e.com/store/custo...&cat=19&page=1 this should do what you want. What torque converter are you planning on using?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
350whp is pretty mild compared to what some ppl are running on 700r4's. i think you'll be fine with a fine rebuild, such as Pro Built. heard nothing but good things from them
Car: 88 GTA
I plan to run probly a 2500 stall
i drive the car everyday to overdrive is a must if i could afford a 6speed I would!
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
probuilt street/strip and an edge torque converter.
never have to worry about that half of the drivetrain again.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
