BULLET PROOF 10 BOLT? You be the judge!
Old Nov 29, 2006 | 07:52 PM
  #51
Zdaddy's Avatar
Car: 1987 Camaro IROC-Z
Transmission: T5 currently
Axle/Gears: 10-bolt Moser/Richmond 2.73
Originally Posted by Sonix
He said in his first post that he had those welded on.
Not sure why this thread has gotten so much arguement, he's not exactly the first person on here to beef up a 10bolt...?
I'm still wanting to see where it's tied onto the tubes. Also, where the tubes preloaded.... in tension? ie, preloaded to pull the tubes backwards?
Well, I don't have a good downward picture so I did this quick rendering for you, hope it helps. I put about 10 inch lbs of backwards preload. not enough to pull anything out of place.
Old Nov 29, 2006 | 07:53 PM
  #52
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
I don't think they were welded on the diff cover.
I haven't been to this forum in a few years, so I haven't been up to date on some things.
But I'd take that 10 bolt over any 9". If you look at the picture it looks like there's brackets welded to the alxe tube. (hope he "tied" it with a double knot) or was it Gorilla Glue? He probally does have some preload on it.
<---- this guy is great!
Old Nov 29, 2006 | 08:15 PM
  #53
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Data for your research:
Just wanted to say that I sheared 3 or 4 teeth off of the pinion in my 94 rear with GM 3.73s. I think it may not have been set up perfectly by the previous owner because it whined a little when coasting. The gm 2.73's held up fine with 225 tires. Now I have Richmond 3.23's that are silent and were strong enough to outlast the WCt5 tranny(broken 3rd gear).
I never thought of bracing the rear... I guess I'll try that after I get a tranny. I wonder if the brace idea would be any better on the 4th gen rear, being almost 4" wider, allowing the brace to be wider too?... probably negligable effect.
Old Nov 30, 2006 | 12:25 AM
  #54
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Interesting... Thanks for the drawing, looks like it took a bit of time!
I figured you'd have to have angled the tie rods, in order to get it to "pull" the tubes backwards, rather than just inwards..? But yea, it looks like that would work. Those tie rod adjusters show as being $160 from summit, sounds kinda pricey, but I guess rod ends cost $$, and for 4 rod ends, with a bit of welding, you're pretty much at that price if you made it yourself.... but since it's not really moving (very little when it flexes), I wouldn't think you'd need a spherical bearing rod end, perhaps a solid rod end would have done the job...?
92RSS - Zdaddy mentioned that he had his summit girdle given to "someone" who welded on tabs with bolt holes. It's not a stock feature, (unless you get the LPW or thunder racing version IIRC).
I know "they" (probably LPW?) makes a bracing kit, very similar to what Zdaddy has done. I *think* F-bird'88 has it, I know he's posted a link to the webpage where it's sold. I figured that's just going too far for a 10 bolt, but whatever.
But anyway, just pointing out that this setup is available to buy, so it's not like Zdaddy is really re-inventing the wheel here, he's found one of the common weak points, and addressed it.
FWIW, to my 10 bolt, i've;
welded tubes to center housing
solid pinion spacer, torqued nut to ~240ft/lbs
summit girdle.
zytanium cross shaft (friggen hard to find! and not worth it IMHO)
Still using stock gears, axles, and posi.
I think i'm going to fab up an 8.5" for my next 3rd gen. More for the learning experience in the fabrication area that any other reason, but also because of the power output of my next car... (still in dreaming stages).
Old Nov 30, 2006 | 06:43 AM
  #55
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i would imagine you wouldnt want to pull them backward, just tight. unless its a strip only car, then it wouldnt matter.
Old Nov 30, 2006 | 11:15 AM
  #56
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
http://www.lpwracing.com/p_axletubebrace.asp
Includes instruction section if you search a little.
Old Nov 30, 2006 | 06:50 PM
  #57
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
for your info. on the twisted pinion shaft It was an aftermarket gear set I think 3.73s dont no the brand. the stock 2.7? set broke a couple weeks earlyer riped the teath off the ring gear after one wheel wheel hoping burn out! I belive as mentioned earlyer the (one) week piont of the 10 bolt is the case itself the ring and pinion try to push apart lateraly under heavy load reducing the contact patch. Just one slip and it is broken! you can strengthen
the back of the case (it will help) but you can not stop the front of the case or the pinion shaft it self from flexing!
just the same if it works for you go for it.
keep your AAA mebership up to date!
Old Nov 30, 2006 | 11:00 PM
  #58
AKToast's Avatar
Car: 91 sonoma
Originally Posted by chevymec
Nah, they got the good ol' 7 5/8. The ZR2 package was a suspension/appearance package. You can take the guts from an s-10 rear and run in a camaro rear.
You're thinking of the ZQ8 package. The ZR2 package was an off-road option with 31" tires and a wider suspension. All ZR2 s-trucks came with a 8.5 10 bolt with 3.73s and the Gov-loc. Some 2nd gen s-trucks that had a 4.3 v6 and a stick also got the 8.5. There are 3 different housings since the 4x4 rear is 4 inches wider than the 2wd, and the ZR2 rear is 4 inches wider than the regular 4x4.
-Ralph
Old Dec 1, 2006 | 09:16 PM
  #59
Zdaddy's Avatar
I don't need AAA, just logic. The front of the differential isn't the leak point, rather the rear, more specifically the main bearings allow the carrier to pivot away from the front of the main housing reducing critical contact with the pinion. And the whinning noise is a good indication of incorrect lash. The force that pulls the carrier section away is the axle shafts propelling forward. It doesn't work if the parts in the diff are inferior or installed incorrectly. The axle tube supports are just one part of the total equation to a strong unit entirely....
One more illistration-
Old Dec 3, 2006 | 11:53 PM
  #60
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Never heard of the richmond power trax just eaton posi. Interesting.
Old Dec 7, 2006 | 07:59 PM
  #61
Zdaddy's Avatar
It's kind of like having a spool and open diff at the same time! Feels a little strange at first, but you get use to it....
Later
PS- I have a volunteer test subject on a 4th Gen producing 400hp. Will document the work and we will see how it does in this application. Appreciate the go at it Walter!
Old Dec 22, 2006 | 10:34 PM
  #62
Zdaddy's Avatar
4th Gen Test Differential
Here are the 1st pics of the test differential provided by Walter. This will be installed on a 400hp car for drag racing and auto crossing.
PS- I polised the cover.....
Old Dec 23, 2006 | 01:09 AM
  #63
Sonix's Avatar
Car: 1982 Trans-Am
Walter?
Hey, you never found the moroso cap studs part numbers did you? I glanced through the thread and I don't think you mentioned them?
Reason I ask is that I can't seem to find any specific to this application. Well, I think TA racing makes a set, but it's $25, unless you buy their girdle. I think other companies make them for other rears, and I *think* the GM 8.5" kit has the same bolts, and would interchange, but i'm not 100% on that.
Old Feb 11, 2007 | 11:00 AM
  #64
Zdaddy's Avatar
couple months later...
both 10 bolts still cutting 1.6 60ft's, both cars in the high 400rwhp, both car's in the high 11's 1/4 mile, both diffs in fantastic condition! Holla at cha boy! 3rd and 4th gen camaro's. All tests done and you draw your own conclusions.....
LATER
Old Feb 11, 2007 | 05:20 PM
  #65
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I'm cutting mid low 1.6's on my stock 9-bolt.
Hit them with some 1.4x-1.5x 60fts and see how they hold up.
Old Feb 11, 2007 | 06:09 PM
  #66
dyrt's Avatar
Car: 86 Regal Limited
Engine: 95 cop lt1
Transmission: t56
Axle/Gears: 8.5" gn/3.73 gears
-Ralph
this is true. i have a 2wd 2dr 2000 blazer and it has a 8.5"
Old Feb 11, 2007 | 07:56 PM
  #67
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Zdaddy, please post more pics of the rear of your car......Also would love to see the underside...The exhaust and such...Your car looks jam up dude, PLEASE post me some pics, along with info, on what youve have done...I love the way the exhaust looks...Im kinda wanting to go all out on my exhaust while I have it down for the SFC's install...any info you could yeild to me would sure help.How ahrd was it to do the duals, and did you do them, or farm it out to a shop......Once again AWESOME ride, Thanks, Tom
Sorry to hijack your thread..l
Old Feb 11, 2007 | 09:31 PM
  #68
Zdaddy's Avatar
I'm pushing the car to the 600-700hp mark next month with an extreme concept motor and pushing the V7 on up to the 20-22 psi level. Should be easy 10's in 1/4. Will let you know the results then as well....Sure there is a breaking point, will let you know when that is. Do not intend to push anymore hp than that due to car's primary function will be Time Attack this year....
PS, don't need to slam the clutch at 5k and cut a 1.4 60ft time to get a good 1/4 time...when the boost spools I'm gone. That extra car length most get on me out of the whole is just short lived false hope. Unless your a 9 to low 10 sec street car...most aren't.
Gallileo60, goto my cardomain. If you need more, PM me.
http://www.cardomain.com/ride/2496232
Old Feb 12, 2007 | 10:37 AM
  #69
I saw axle brace kits with differential covers in the most recent JEG's magazine that I got last week. brand is Ultimate.
Old Sep 1, 2007 | 10:24 AM
  #70
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: BULLET PROOF 10 BOLT? You be the judge!
any updates on the bullet proof 10 bolts?
page 180 r in the new jegs catalog. if you look real close at that picture you'll see the word ultimate across the back of the housing cover. and at the base it's marked lpw. that looks like it's the lpw stuff being marketed under the jegs logo. i really don't have a problem with this though, i haven't ever heard of something they put their name on having a problem(not that it hasn't happened). besides, it's cheaper at jegs!
the axle brace kit is way more expensive than through lpw though
Eric B
Old Sep 1, 2007 | 01:18 PM
  #71
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
looks sweet
Old Jun 17, 2008 | 03:41 PM
  #72
Zdaddy's Avatar
Eric B
OK, so here is the update...........
Car is making 600 RWHP (750 GROSS). I've made one event at a Dyno Day, Maxton Mile for Land Speed and one event at VIR for an SVT Cobra event (fun driving against the Mustang crowd). On the 12th lap at VIR on the full course, shifting to forth gear on the back straight at 140ish and then BLAM, clunk, clunk. clunk.....I tore the center right out of my new race clutch disk......lol
The differential is still fine BTW.
Old Jun 18, 2008 | 12:55 AM
  #73
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
lol,
thats great. iam glad you posted this. iam building mine up now too.
Old Jun 28, 2008 | 11:07 PM
  #74
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I'm also going to run the Ultimate 10 Bolt cover from Jegs.It is made buy LPW racing products (Arrived just yesterday)Its going over my new Eaton Posi and 3.42 gears.Its only a stock daily driver but cant hurt to add a little extra to a 10 bolt. http://www.lpwracing.com/
Old Jul 25, 2008 | 04:42 PM
  #75
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
I am going this route as well. Does anyone have any information as to where I can get the solid pinion spacer? I have triedto reach Drivetrain Direct, but the 888-584-4327 number does not work from Canada.
Old Jul 25, 2008 | 04:52 PM
  #76
Sonix's Avatar
Car: 1982 Trans-Am
only one company on earth makes this, Ratech
http://www.ratechmfg.com/contactus.htm
I just phoned them direct and ordered one from them. $20 part, $50 shipping (with border fees). Kinda a rip off.
It's quite literally a short piece of pipe. You can probably get a machine shop to make you one for less then that actually. Measure up your old crush sleeve, and get a piece of pipe/tube of that ID. OD isn't crucial. Then cut it .010" shorter, and find some shims (machine shop). Then just use that.
Old Jul 25, 2008 | 07:28 PM
  #77
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
bought mine at summit racing $16 her is the link
http://store.summitracing.com/partde...5&autoview=sku
Old Jul 25, 2008 | 08:28 PM
  #78
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Great! I bought some parts from Summit two months ago and asked them about this piece, they did not have it at that time so must be new stock. Thanks!
Old Aug 4, 2008 | 06:45 PM
  #79
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Glad to hear the rear is still holding up, great thread & Beautiful car!
Old Mar 17, 2010 | 04:50 AM
  #80
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
any updates?
Old Oct 15, 2012 | 10:00 AM
  #81
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
It's still living. Over 600rwhp. T5...... not as lucky!
I'm doing a 9" and T56 as we speak...
Old Oct 15, 2012 | 03:10 PM
  #82
ownor's Avatar
Engine: LS1 / L03
nice.. what upgrades did you do on that 10bolt, and what milage did you put on since the swap? and what tires, and driving/racing style plz
edit: oh man this has been so long i even forgot what that thread was all about LOL!
i'm back up to date now. just need some more infos on the driving/racing you're doing, tires, milage would be interesting as well.
way to go on building a 10bolt! i got the LPW stuff kicking around for almost two years now, but not gonna need it until i swap over to the new engine... ^^
Old Oct 15, 2012 | 04:26 PM
  #83
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Well, honestly some pretty grippy Potenza 19's, but no drag racing.
It currently has probably 1000 miles and since I bought the car a couple years ago no drag strip launches...
I actually TTTed the thread as someone is looking at buying it and I wanted to make sure I could find the thread in the future....
Old Oct 15, 2012 | 05:14 PM
  #84
ownor's Avatar
Engine: LS1 / L03
np on the TTT imho with no drag strip (how about other hard?) launches it's hard to say.. Potenzas sound grippy tho yep. thanks for the update all the same
Old Oct 17, 2012 | 10:10 AM
  #85
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
They are pretty grippy, but I've been pretty easy on it as I was fearing for it and the T5(which broke)
Rear is now for sale....
GTAman
Jul 3, 2024 07:29 PM
F-body driver
Mar 6, 2023 11:44 AM
Logan Bryant
Sep 18, 2016 09:27 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
