Install B&M in a th700r4
Old Nov 26, 2006 | 02:46 PM
Tyson's Avatar
Car: Camaro IROC-Z
Transmission: th700r4
Axle/Gears: 2.77
Can I install a B&M Transpak Kit together with a B&M TH-700R4 Wide-Open Throttle 3-4 Upshift Kit
I allready bought the Transpark Kit http://store.summitracing.com/partde...5&autoview=sku and will install this at the same time http://store.summitracing.com/partde...5&autoview=sku
together with a new converter
and a megashifter http://store.summitracing.com/partde...5&autoview=sku
My camaro got a 350cid and 2.77 ratio ,by the way !!!
Old Nov 26, 2006 | 03:24 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i had b&m shift kit installed in my 700r4, i had major slipping problems i installed transgo shift kit made night and day difference.
Old Nov 26, 2006 | 04:12 PM
Tyson's Avatar
Car: Camaro IROC-Z
Axle/Gears: 2.77
I have heard that to about B&M shift kit ,but I already got it and my friend had it in his IROC-Z whithout any problems so after all I going to install it anyway!
Old Nov 27, 2006 | 02:26 PM
Shagwell's Avatar
Car: projects.......
Unless you do A LOT more modification than the crappy trans-pack, don't put the WOT upshift valve in. OD was not made to handle wot assaults and the trans will come apart.
Old Nov 27, 2006 | 04:34 PM
Tyson's Avatar
Car: Camaro IROC-Z
Axle/Gears: 2.77
So this kit from transgo will be a much better result than the B&M Kit without the Wide-Open Throttle 3-4 Upshift Kit ??
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
