350 turbo build
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
350 turbo build
ok guy i know this has been asked manny time i cant finde whee it at on here so im going to ask agean. im dropping a 350 turbo long tail shaft into my 84 trans am what all do i need to make sure this bolts up and that my drive shaft will fit like it should im new to all of tihs so any help would be good
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I have been reading your posts and all of the problems that you have encountered.
My advice would be to buy an late model vortech engine and transmission from the junkyard to install in your car. I think a 2 wheel drive truck would work.
Pull the fuel injection off the junkyard motor, put a vortech intake, your existing carb and non computer distributor in on the junkyard engine and drive on.
You are most likely able to buy both a running 350 and trans for what its is going to cost you to fix the former owners mistakes.
May the force be with you.
Engine: 383 stroker
Transmission: th350
already bought a 350 and a 350 turbo i just need to know what all i haft to buy and do to make sure my trans will work and all
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if it's the 9" tailshaft TH350 then the driveshaft will bolt up. You will need the B&M TH350 swap kit to mount the trans mount and torque arm mount.
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Aug 24, 2015 09:01 PM
