ring gear spacer for 9-bolt
I've spent most of today trying to find if a ring gear spacer can be used on the 9-bolt rears to get from a 2 series to a 3 series gear set. I've seen some people say you can, some people say you can't.
A) Can a ring gear spacer be used?
B) If so, how thick does it need to be?
The rear I have has a 2.77 ratio right now, I'd like to go to 3.70's, and I'm tired or searching for a 3 series rear.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You would not want one on a 9-bolt. There is not enough shoulder on the carrier to supprt it. That means all the load would be on the bolts and they would shear off.
*EDIT* After getting the rear apart and taking the ring gear off I now see what you were talking about Don. 3/8" of shoulder and an assumed spacer thickness of 1/4" doesn't leave much in the way of contact surface, not to mention the chamfer on the gear itself. I may have to rethink this afterall
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
