Powertrax unit
Old Dec 21, 2006 | 05:33 PM
Camarodadd's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 406
Powertrax unit
I've got a stock rear end in my 92 and want to install a powertrax unit. Anyone know the part number for this? I't my understanding that I've got 28 spline axles and Summit hasn't been a ton of help in which one to get.
Anyone know?
Old Dec 22, 2006 | 02:02 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Their is only one for a 7.625" 28 spline 10bolt....
Shouldnt be a difficult decision on which one to get!
Old Dec 23, 2006 | 09:53 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Save the extra 100 dollars and get a true posi like a trutrac or an eaton.I absolutely HATE my powertrax unit.The popping around corners drives me nuts.Sometimes if coming out of a turn it doesn't engage till after you start going straight for abit and locks in and causes quite a "wiggle".
Old Dec 23, 2006 | 07:47 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
yep, i had a powertrax in my old s-10 and it sucked *****, id rather DD a full spool than one of those, the detriot true trac is what i'll be running in my 9"
Old Dec 23, 2006 | 09:25 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
The only thing that sucks about buying a whole posi carrier is you either have to **** around yourself or pay to have a shop set up the gears.
At least with a powertrax type unit you just pop it in and go, no pissing around or extra costs!
But i do agree, picking up a new carrier is the better way to go...
Old Dec 28, 2006 | 03:54 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'm not a fan:
Old Dec 29, 2006 | 12:24 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
damn, that makes me never want to buy a powertrax. Was that the lockright or the no-slip?
Old Dec 29, 2006 | 03:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have one, its just an attempt at getting a little more traction until i get my 12 bolt. and i got it cheap, like 200$ its a little weird driving it when its locking and unlocking and sometimes the car seems to wander about on the road when you are at wot
Old Dec 29, 2006 | 06:32 PM
mw66nova's Avatar
Engine: 7.0L
it's the original version of the lockright that they made back in the late 90's, though the new design doesn't look much stronger as EvilCartman has broken his newer style as well.
Old Dec 31, 2006 | 01:40 PM
Pat Hall's Avatar
Listen to these guys! Powertrax units suck a s s! I used the same line of logic as 84Z28350 and decided to run one since I could avoid having to set up the backlash on the new carrier assembly. I wouldn't run another one of those things if someone gave it to me for free. Jerky, noisy, scary around corners, and just downright miserable on the street. Save up the extra money and get a clutch style posi or zexel-torsen unit. I wouldn't count on Summit to be much help either, that's who sold me my powertrash unit when they first came out, and they were trying to convince hot rodders that they were the greatest thing since sliced bread. They're great for off road vehicles, but have no place in a street/strip car. If you have the original rearend in your car, you definitely have 28 spline axles. They changed from 26 spline in late 89.
Old Apr 10, 2007 | 09:17 PM
hatebur2001's Avatar
Car: 1992 RS
Engine: 3.1
Transmission: 5 spd
Re: Powertrax unit
Check this site for a good summary of the differences between differential types.
I was thinking about the Powertrax unit as well, but my Camaro is not a rock crawling 4X4.
http://www.angelfire.com/my/fastcar/diffey.html
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
