Fixed the common rattle
Old Dec 31, 2006 | 12:48 AM
Pocket's Avatar
Car: 91 Trans Am
Read a few posts about the common rattle associated with 3rd gen automatics
Mine got progressivly worse over the last year and i was gonna find out what was doin it
Its the torque converter to flexplate bolts
Apparently GM didnt locktite those bolts, one was missing, one was about halfway worked out and the 3rd was finger tight
30 mins and i got a quiet idle for the first time since Ive owned the car
Take it for what its worth
Old Dec 31, 2006 | 02:26 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
yeppers i had that problem with my old 89, one was MIA and the other 2 were loose as a goose, had they all fallen out, that coulda been bad...
Old Dec 31, 2006 | 03:37 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i lost a TC bolt a few months ago hotrodding around w/ a couple 3rd gens...wheels i think that's the only time i've seen your z on the road, haha.
...when you're down there, double check to make sure the flexplate bolt holes aren't elongated.
Old Dec 31, 2006 | 09:53 AM
Car: 91 z28
that one hurt i guess you really dont want that tranny and gears huh??!!!!
Old Dec 31, 2006 | 10:28 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Any pics of where I can find those bolts?
Thanks, and happy New Year from the Netherlands!
Old Dec 31, 2006 | 04:04 PM
Car: 91 z28
where the transmission meets the engine, on the underside of the car. The torque converter bolts to the flexplate, these are the bolts we are refering to, hope these pics help (first ones i could get)
Old Jan 1, 2007 | 02:50 AM
Thanks for the pics!
I haven't been under my car for some time now, but it seems from the pics, some cover has to come of, before you can reach those bolts, right?
Old Jan 1, 2007 | 04:48 AM
Pat Hall's Avatar
Yeah you have to remove the inspection cover first. Only 4 bolts, takes about 5 minutes.
Old Jan 23, 2007 | 12:33 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
can I remove the inspection cover and check this??
Is it true that if i turn it with a big flathead screwdriver, and both the flexplate and the torque converter dont turn together then there is a problem with the bolts???
Elephantismo
Feb 13, 2019 12:51 AM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
