Switch to ST10 from T5 in 87 GTA
Old Dec 31, 2006 | 10:33 PM
ExRacer's Avatar
Ok people, I searched but couldn't get the right thread. I have an 87 305/T5 road racer that won the Nationals this year, but is getting upgraded to a ZZ4/RichmondT10, Currie 9" rear powertrain. I need info on what configuration is the best for my bellhousing, clutch, flywheel and starter as well as any crossmember problems.
I have an old manual Z bar Corvette aluminum bell, the original hydraulic clutch 305 bellhousing/flywheel, a flywheel that was used with this trans and engine in an ASC (NASA) stock car with the ZZ4 with one of those concentric Quartermaster inside-bellhousing clutch release mechanisms, and the used original raced Quartermaster clutch.
My intent is to use as much of the 87 bellhousing/hydraulic clutch release mechanism and then get another Quartermaster clutch to keep things simple. I have been told that the trans crossmember must be modified or some aftermarket item purchased. As usual I'm on a strict budget and would like to do as much of the mods as possible myself.
Help! Anybody done this already?
Old Jan 1, 2007 | 11:53 PM
ExRacer's Avatar
I found the Spohn toque arm and crossmember here http://tpiparts.net/inc/sdetail/2675 and would like to adapt my parts to accomplish this. Has anybody done this with a Currie (Ford 9") rear end? Or is the Spohn the only aftermarket solution? Thanks for any reply . . .
sheachopper
Jul 31, 2019 11:27 AM
Veaceonee
Sep 29, 2016 08:15 PM
timonator
Sep 30, 2015 12:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
Isaac McCormick
Sep 12, 2015 10:20 PM
