hedman longtubes and bellhousing problem!!
Old Jan 20, 2007 | 03:46 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
Hey guys im using hedman longtubes #68469 (longtube D-port). For some reason the bellhousing is hitting on the header collector not allowing it to fit on. Has anybody used these headers with a standard? Any help would be appreciated, this is getting frustrating!!!
Old Jan 20, 2007 | 11:12 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
If you read the footnotes in the Hedman catalog you will see that they are for automatic cars only. Footnote number 135
http://www.hedman.com/pages/hedmanmain.html
135 Transmission size limited to 700R4 and 350 Turbo.
You will have to trim the bellhousing and possible rework the header to make it clear.
Old Jan 21, 2007 | 12:39 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
yeah i read that on hedmans site after i posted. I trimed the bellhousing to fit but now im afraid of the slave cylinder (i think thats what its called) melting. It's too close to install the heat shield and the slave cylinder is only about 1/4" away from the header collector. I thought about drilling the holes over 1/4" to clear up some room but i dont want it to angle too much. There sure isnt much room to work with. Anybody have this problem before?
Old Jan 21, 2007 | 08:28 PM
Comp788's Avatar
I have seen people use a HYD throw out bearing to resolve the issue. The slave cyl is too close to the headers for it to survive.
Old Jan 21, 2007 | 10:17 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
could you explain how a hyd throw out bearing works and how it will resolve the problem? Im not too familar with standards.
Old Jan 21, 2007 | 11:06 PM
Comp788's Avatar
Check out McLeod Industries. Here is a link to the page showing the HYD tO bearing.
http://www.mcleodind.com/ProdGuide/P.../Page%2010.pdf
Old Jan 22, 2007 | 03:01 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
could somebody help me out with the part number? I have a tremec t-56 and i believe its a 5-speed bellhousing. Is there any other companies that make the hyd. throwout bearing, those are very pricey from mcloud.
Old Jan 22, 2007 | 03:43 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
HOWE RACING
check Summit Racing for products w/ prices
Old Jan 22, 2007 | 06:09 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
i dont see one with made by howe for the tremec t-56 am i missing something?
Old Jan 22, 2007 | 06:14 PM
5678TA's Avatar
Car: 1984 Trans Am
my bad.. forgot you dont have a t-5
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
jtwoods4
Sep 3, 2015 05:39 PM
greenyone
Sep 2, 2015 03:39 PM
Dialed_In
Aug 20, 2015 01:45 PM
