8.5" 10 bolt availiblity?
Old Jan 22, 2007 | 02:14 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
wondering if there is any info on what rear ends might be able to be swapped witht he weak stock rear. i'm wanting a 8.5" more than good enough. and some people debate that its better than a 12 bolt because of reverse threading and actual claping surface area of the bolt head on the ring gear. also requires less power to turn, and my car should be straining it too much, street car with 500hp ( lets hope a 406 with 195 afr heads can pull it off)
cheers
blake
Old Jan 22, 2007 | 03:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's nothing stock that'll swap right in. You could get real lucky and find a Dana 44 in a junkyard, but apart from that you'd either have to do a bunch of fabrication youself, or get something from an aftermarket vendor.
Old Jan 22, 2007 | 03:52 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
anyone have a data base on rear end width, specificaly for the 8.5"?
nothing a litttle welding and cutting cant handle. do you relocate the brackets on the rear end housing for lower control relocation brackets/
Old Jan 22, 2007 | 04:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Don't forget there's the torque arm to deal with.
This has been discussed a number of times. A search should turn up the relevant details.
Old Jan 22, 2007 | 09:57 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Check out amazingmechanical.com They make an 8.5 for the 3rd gen. I found it while reading Quick Times Magazine. I'm not looking to do my rear yet so I haven't called them. There is no prices on the website. I think they are in Edmonton so they don't have to ship across the boarder. If you check it out let us know.amazingmechanical.com
Old Jan 22, 2007 | 10:32 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
thanks man i just emailed them. i'll post a price for everyone
cheers
blake
Old Jan 23, 2007 | 12:25 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
3400 canadian with torque arm provision, 30 spline axles
eaton posi
Old Jan 23, 2007 | 05:47 PM
WillSpeedy's Avatar
Is that with tax, shipping and a BJ?
You could get a moser 12 bolt for cheaper than that I'm sure.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
