1992 Z28 has a G80 rearend
Old Jan 23, 2007 | 07:19 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Hi! Can anyone tell me what size the rear end is? Or do i have to go out in the snow and look for the code on the axle? Thanks
Old Jan 23, 2007 | 08:09 PM
It's a 7½" 10-bolt.
Old Jan 24, 2007 | 06:28 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
G80 is the RPO for the Limited Slip rear option on the 7 5/8 10-bolt. For the gear ratio you will need the RPO code or pull the cover.
Old Jan 24, 2007 | 08:45 AM
"Codes" are worthless. All they tell you, is what the rear end housing came with; not whether it's the rear that came in the car, or whether whatever it came with, is what's in it now. That includes "G80". All that means is that the car's original rear CAME WITH a limited-slip carrier; that may have no connection whatsoever with what's in it now.
If you want to know what's REALLY inside your rear end (your car's rear end, that is...) the only way to know accurately is to take off the cover and look.
Old Jan 24, 2007 | 09:43 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
10 bolt cover = 7.5" and 7 5/8" 10 bolt corporate
9 bolt cover= borg warner
G80= limited slip unit
thats it
simple
Old Jan 25, 2007 | 01:26 AM
Car: 1992 Z28
thats it
simple
OK, so how do i know which it is? A 7.5 or 7 5/8? I need to figure this out like now, cause i have a guy who has a series 3 eaton posi unit i want. Thanks
Old Jan 25, 2007 | 05:52 AM
A 7.5 or 7 5/8?
Right, that's the one you've got; not the 7.75".
Old Jan 25, 2007 | 02:56 PM
Car: 1992 Z28
So i have the 10 bolt 7.5 then? Just to clarify.
Old Jan 25, 2007 | 03:02 PM
Right; the 7.5"/7.625".
There's no difference, except for some details inside the carrier. The carriers are the same as far as how they bolt in, and all carriers interchange into all housings, and all gears bolt onto all carriers. Subject of course, to the 2 series vs 3 series constraint.
Old Jan 25, 2007 | 10:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 10-bolt is 7 1/2" up to 1988, I think. Then its 7 5/8". They're interchangeable, as said above.
64Chief
Sep 12, 2015 08:05 AM
dementednut
Sep 10, 2015 09:50 PM
challenger71
Sep 10, 2015 04:58 PM
Ranbo108
Sep 9, 2015 12:20 PM
