lock up switch installation
Old Feb 2, 2007 | 12:45 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i had brought my car to get a shift kit, and 3000 stall to get installed in my 700r4. he said he wired a lock up inside the transmission i just need to set up the switch? now he gave me a connector, which was broke, that goes on the side of the transmission and said just go pick up a new one and run the wire to the on/off switch and other to ground. Then ground the switch, and also stick one wire in the fuse box (three wires coming from the switch)
is this all that needs to be done to get my lock-up working on my transmission?
Old Feb 3, 2007 | 03:32 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
TTT if anyone knows what im talking about..
Old Feb 3, 2007 | 03:44 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The lock-up solenoid is switched on by grounding it. Did he tell you which wire goes where, or do you need a wiring diagram? The connector should be a 4-pin weatherpack (2X2) that plugs in the trans.
Old Feb 3, 2007 | 06:43 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
so its called a solenoid. I did a search and this is what i came up with:
- Purple(12v - Goes Off When Brake Is Pressed)
- Tan/Black(Ground From ECM To Tell TCC To Lock Up)
- Green(To Tell PCM When Transmission Is In 4th Gear)
I read about ALDL but my harness is all hacked up due to previous owner and me installing 4th gen dash. Can i bypass this since i have on/off switch? which wire would i need to connect the on/off switch to on the solenoid? Green? or Purple?
Old Feb 4, 2007 | 10:08 AM
Lo-tec's Avatar
http://www.technicalevolution.com/700inst.htm
This has all the info you need to wire it up.
Old Feb 4, 2007 | 11:37 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
all inside the transmission is wired, im just talking about the 2x2(4) prong that clips on the outside of the transmission.
a, b, c, d
there are only 3 wires that actually come from the prong im told, A is for 12v power, D is for ground, and i am not sure of the other one, is the wire the i would wire to the On/Off switch?
Old Feb 4, 2007 | 12:22 PM
Lo-tec's Avatar
Correct. Run a 12V key on to A, and run a ground switch to D. Get a on/off switch, run one side to ground and the other to D on your connector. When it is turned on it will be grounded and turn on the TTC solenoid. B is the 4th gear switch, and not really needed unless you want to get fancy.
Old Feb 4, 2007 | 12:53 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
A is it 12v constant or ignition?
then i use D(ground) to connect to the switch, and run the last 2 wires on the switch to ground and fuse box (has 3 wires im assuming fuse box is for IGN).
Old Feb 4, 2007 | 01:22 PM
Lo-tec's Avatar
A is 12V+ ignition (key on), not constant. Run a wire from D to your on/off switch. Run the other wire of your switch to ground. When you turn the switch on D is grounded and the TCC locks up. No other wires are needed, and nothing from the switch goes to the fuse box.
Old Feb 4, 2007 | 03:50 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok, and B is not needed, sweet.
So i can just leave the 3rd wire from the On/Off switch alone then, what would happen if i had it plugged it, just means the switch would only work when IGN is on right?
Old Feb 4, 2007 | 04:16 PM
Lo-tec's Avatar
The switch just grounds out the TCC solenoid, making it work. It is an On/Off switch. When you turn it ON, the wire that runs to ground connects to the wire run to terminal D and activates the TCC solenoid. Period. It does not require power to the switch to do this. I don't know what kind of switch you have, but you need one that when you turn it on the two wires coming from it are connected. Period. If you have a continuity tester, figure out which two wires of your switch are connected when you turn it on, and use them. If not, buy a two wire On/Off switch.
Old Feb 4, 2007 | 04:49 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i think the 3rd wire was for the light, it comes on when the switch is on, sorry.
Old Feb 4, 2007 | 04:55 PM
Lo-tec's Avatar
F' the light, just hook up the switch!!
Old Jun 22, 2007 | 01:44 PM
shootryan's Avatar
Car: 85 Chevy Camaro
Engine: 383/holley carb/edelbrok intake
Re: lock up switch installation
so you really only need A and D, is that correct. does anyone have the wire color for these wires
Old Jun 22, 2007 | 09:35 PM
Lo-tec's Avatar
The connector has the letters cast in it. Look at the connector and find A and D and hook those two wires up.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
