Ringgear pattern Help
Old Feb 3, 2007 | 06:12 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Hello Im having trouble getting my attachment up . If someone can help me I can email the photos . It is a youkon 373 with .006 BL all preloads are good.
PM me with addresses or post them up thanks .
Old Feb 3, 2007 | 07:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
http://www.richmondgear.com/ringandpinion.pdf
Old Feb 3, 2007 | 07:33 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Thanks I have the youkon book . I having trouble deciding if I need to move my pinion in deeper .
Old Feb 4, 2007 | 05:28 AM
ede's Avatar
ede
i wouldn't worry about the pattern. if you have pinion depth set to the correct spec and BL within the spec the pattern is going to be acceptable. it's a pretty subjective check as you're finding out. not sure what you're spec is but i'd go up around .008 to .010 on the BL.
Old Feb 4, 2007 | 08:53 AM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Thanks ede my youkon list 2 BL specs . Old step 6-10 and new step 3-6 I do not know what gears I have so, the .006 fell right in the middle
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
dimented24x7
Sep 17, 2015 06:58 AM
armybyrd
Sep 16, 2015 07:00 AM
