9'' FORD ?'S
Old Feb 9, 2007 | 03:14 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
9'' FORD ?'S
What is the difference than to just buy the brackets and put them on any 9'' that will fit or aftermarket? I know that a aftermarket you can get anyway you want it. But is there any weight differences between the two? And I've done some searching and seen where alot people said that they where hp robbers.And I see why they way a ton. Anyone done the 9'' with just buying the brackets?
Old Feb 9, 2007 | 03:31 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i dont see why there would be very much weight difference
any real weight difference would be in width difference between axles, and type and model of carrier
the housings themselves are light, around 40lbs
the carrier and gears are what weigh something
welding the brackets on yourself is the way to go if you have a welder and can find a narrow enough axle to do it to
i dont know what you would use to weld steel brackets to the iron center housing for the TQ arm and such
someone know ?
Old Feb 9, 2007 | 03:34 PM
If you just stick the brackets on some stock POS, then you end up with..... a stock POS with some brackets welded on it. If you buy an aftermarket one, you can get a strong center section, a better housing, and so on; in short, something VASTLY better than some stock POS.
The 9", as it came from its mfr, is a pile of junk. It's weak; nowhere near as strong as a GM 12-bolt (car version). The 9" itself, out of the junkyard, isn't what's so great; it's its usage as a PLATFORM that you can build on. It's a good design, from the standpoint of how it goes together. Quick to change ratios, doesn't use C-clips, and the parts are big enough that you can make replacement ones that are far better than the best you'll ever find in a junkyard.
If all you want is some kind of bragging rights ("yeah, I'm SO BAD, I've gotta have a 9" in my car") then do the junkyard and bracket thing. On the other hand, if you want something that's actually better than what came in your car, go aftermarket.
Also, stock ones are notorious in these cars for creating pinion angle problems. One of the benefits of an aftermarket unit is that it has a chance of ACTUALLY fitting the car somewhat.
Old Feb 9, 2007 | 08:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think Moser still sells the torque arm mount bracket. You cut all the other brackets for LCA, shocks, panhard bar off a donor diff and weld them onto a 9" or if you have any kind of fabrication skills, you make your own. It's the torque arm mount that doesn't make using a junkyard diff easy.
9" diffs also come in many different lengths with different pinion offsets, axles sizes, bearing ends and brakes. You need to know exactly what you're looking for before grabbing just any 9" housing.
My "factory" 9" diff got my into the high 9's. Factory housing and center section. Strange spool, unknown gear brand and Strange 31 spline axles. I welded ladder bar brackets on to eliminate the torque arm. I now have a narrowed diff and a 4-link under the car.
Normally by the time you're don't fabricating and modifying, it can be cheaper to just buy an aftermarket bolt in diff.
Old Feb 10, 2007 | 08:05 AM
Car: 1992 camaro
Axle/Gears: 3:73
Yea I found a company that will sell a housing to fit the camaro for $650 to my door or $950 complet.I dont know if the comple comes with the 3rd member but I all ready have it.
Old Feb 10, 2007 | 07:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
$950 will include the axles with bearings and nothing else. A complete, ready to bolt in and go diff will be around $2500
Just make sure the axles are in the same spline count as the carrier you currently have.
Old Feb 10, 2007 | 10:18 PM
Car: 1992 camaro
Axle/Gears: 3:73
Yea they are 31 And it includes :axels,axel bearings,studs,TA braket
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
