whats the best rear for about 500hp to crank?
Old Feb 11, 2007 | 01:15 AM
chevrunner21's Avatar
Car: 1992 trans am
Engine: 305 tpi
i'm going to try and build a 500hp 383 or i'm going to try and get the most out of the motor that i can, i need to know what would be my best and cheapest rear? it's got a bw 9bolt and 3.7 richmond gears but i would like to use a rear with 3.9-4.11 gears and i need it to handle as much hp as possible. so what will be my least expensive but best route? i plan to launch the car with drag radials so i know i'm going to need a decent rear.
Old Feb 11, 2007 | 01:19 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
9 bolt would be fine with 26" slicks should work out alright
if you want 4.11 gears, then it's 9" and $2300-2800 time. I'm going with exotic performance out of Indiana for my 9" rear end. pricey, but will hold up no problem for what I'm throwing at the car.
Old Feb 11, 2007 | 12:41 PM
Car: 1992 trans am
Engine: 305 tpi
so i guess i would probably destroy the 9bolt with 4.11's? and if i installed a spool and some other aftermarket parts in a 10bolt would it hold with 4.11's? i don't have the money to buy an aftermarket 9" or 12bolt so i'm trying to see if a 9bolt or 10bolt would work.
Old Feb 11, 2007 | 01:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ooooh. Now there's questions that are just looking for problems. Nothing worse than seeing someone wanting to build a high hp engine and scrimp on costs for the rest of the driveline or suspension to handle all the power.
Simplest answer is to run what you have. When it breaks, decide how much you want to spend to put in something strong enough to handle the power. Complicated answer is to buy something that's an overkill. Spend the money now on a 12 bolt or 9" and never worry about it again.
I ran very high 11's at 117 mph on a 3.27 geared 9 bolt before upgrading to a beefed up 10 bolt then finally to a 9" when I put a transmission with a transbrake in.
An inexpensive 9" option is to buy a bolt in housing package for about $1000. You supply your own center section and brakes.
Old Feb 11, 2007 | 03:31 PM
Car: 1992 trans am
Engine: 305 tpi
i don't plan on going over 500hp i might not even make 500 thats what i would like to make would a beefed up 10bolt hold it? or no matter what will i have to go to a 9" or 12bolt?
Old Feb 11, 2007 | 03:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I was putting over 500 to the wheels through a beefed up 10 bolt. Like I already mentioned. Run what you got until it breaks. 10 bolts have been broken by 305's and have also survived behind big blocks.
Old Feb 11, 2007 | 04:06 PM
xpndbl3's Avatar
Car: 1984 Z28
i never consider going from a 9 bolt to a 10 bolt an "upgrade" if anything it's wasted monetary movement. Keep the 9 bolt how it is with 3.70s and save for a 9" eventually, otherwise you're tossing $700 into the 9 bolt for 4.10s once they're installed instead of putting that towards a 9"
anesthes
Mar 10, 2016 10:35 PM
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
mizz0313
Aug 12, 2015 06:45 AM
