trans fluid
Old Feb 16, 2007 | 10:45 PM
toms86Z28's Avatar
trans fluid
how much fluid goes into the 700r4 with a fresh rebuild. my friend gave me 12qt. of B&M synthetic trick shift. trans fluid what do yous' think about the synthetic trick shift fluid
Old Feb 16, 2007 | 11:32 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the only thing B&M i have found that i like is the megashifter that i have. i'm even getting rid of my torque converter. my recommendation is to find some other synthetic to run such as royal purple or amsoil.
Old Feb 17, 2007 | 03:51 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
once you figure out how much the tranny takes, also remember that some has to go into the torque converter.
If you puy in some fluid, turn the tranny over by hand, and then fire it up, it wont damage the tranny. You can prolly figure out the right amount once its in the car and running. Not enough is ok, too much fluid will hurt it though. call up a local tranny shop, im sure they could tell you
Old Feb 17, 2007 | 04:13 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
I like the Mobil 1 synthetic ATF I run, I abuse my tranny and it takes it. Of course this is my fourth torque converter and third transmission. But I've had them for two years now, so it looks like they're strong enough for the motor.
maroe624
Apr 16, 2017 08:29 AM
LittleFranks
Sep 17, 2015 12:22 PM
spaigo
Aug 21, 2015 07:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
