P-N-R super slow when temps cold
Old Feb 18, 2007 | 11:05 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Year round my park to neutral and from neutral to drive are slow but in the winter I have upwards of 6 seconds for the tranny to shift out of one gear into the next. Summer timeframe is only about 3 seconds.
All other shifts are fine regardless of tranny or ambient temperature.
Is my pump taking a dump?
Valve body dirty?
Old Feb 18, 2007 | 11:13 AM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Low and or wrong fluid and/or dirty filter. 3 seconds to go into gear is a long time.
A pump leak (Internal) can do it too.
Old Feb 18, 2007 | 11:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Well then maybe I'm looking at a pump leak. Filter's new and level is actually a little over full. Fluid Dexron-Mercon III.
Old Feb 18, 2007 | 09:50 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
nods... pump vanes are a wear item.
You're losing pressure somewhere. Loose valve body bolts could do this too, or a broken accumulator spring.
Old Feb 19, 2007 | 08:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Thanks for the info. Hopefully the tranny holds out until I can get the GTA put back together.
Old Feb 19, 2007 | 11:07 AM
Engine: 350 SBC TPI
There is a test port on the left side where you can test it.
Old Feb 19, 2007 | 11:10 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Test port? I'll do a search on that unless you want to tell me how and what I need to test.
Old Feb 19, 2007 | 12:07 PM
z28man355's Avatar
Car: 87 camaro
Engine: 355
Transmission: 2800 stall 700r4
Axle/Gears: 7.5 4.10 auburn posi
The test port he is referring to is a 7/16 head hex plug on drivers side of trans right above the shift arm. rem ove the plug and install a trans pressure gauge and ck pressures in park and in gear. If I remember right somewhere around 65-80 psi in park
Old Feb 20, 2007 | 07:54 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Cool. Thanks.
Replacing the pump means pulling the tranny doesn't it. Maybe I should just go through the whole thing while i'm at it.
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
