Transmission mount to Transmisson bolt size?
Old Feb 17, 2007 | 01:44 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I need to know the size of the middle bolt that the tranny mount bolts into the tranny. One of my bolts feels to short and when you really tighten it, it jumps a thread back. The longer bolt goes in tight then when you take the socket out, it makes a 1/8 of a turn loose by itself. the bolts I have are like a 1x1.5 or something like that. What size bolt do I need?
Old Feb 17, 2007 | 02:28 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Nobody knows??? I really need to know the size of this bolt because it is my daily driver and I need it to get around.
Old Feb 17, 2007 | 03:32 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have a M10x1.5 right now. Does this sound correct?
Old Feb 17, 2007 | 04:03 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, So I checked and I have the right bolt. When I put it in, I can't thread it in by hand, so I don't think it is stripped, but when I tighten it, it gets to a certain point and it feels tight. When you tighten it a little bit more, it gets loose and and can't tighten in enough.
Old Feb 18, 2007 | 10:15 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Thats a stripped thread. You need to drill it, tap a larger size bolt now.
Old Feb 19, 2007 | 03:43 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I am going to use a helicoil. Anyone use one before? I just spent $40 on the stuff I need so I hope it works.
Old Feb 19, 2007 | 05:17 PM
player 88's Avatar
Engine: 360 .060 over TPI
Helicoils work awesome and are stronger then the aluminum threads were.
Steve
Old Feb 19, 2007 | 08:41 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Worked out great. At 40 dollars though . After we put the helicoil in, I realized that I could have just stuck a bolt in there and been good to go. O well, at least it will be stronger!
Old Feb 20, 2007 | 07:56 AM
player 88's Avatar
...and it is done right!
jhawkeye
May 25, 2022 06:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
Elliswon
Aug 10, 2015 12:33 PM
