4th gen rear swap...
Old Feb 21, 2007 | 01:03 PM
LT4Hawk9's Avatar
Car: 1997 LT4 Firehawk
Engine: 350ci LT4
Transmission: MN6 6 Speed
Axle/Gears: 3.42:1
Since the search hasn't worked for me all day...I've got an '87 TA with a drum rear, and a disc brake rear end from a 99 Firebird. What kinda funky stuff am I going to run into? E-Brake cables gonna work (I've got the one from the '99 still with the rear), master cylinder, prop valve, etc? I want to get all the parts together that I'm going to need before it happens, so my down time is as short as possible.Thanks!
Old Feb 21, 2007 | 10:01 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I've done the swap with a 94 4th gen rear and the only thing that is different is the rubber soft line that connects the rear brakes to the rest of the car and the e brake cables. I had to use the T connector that was on the car origianally and screw the hardlines on the new rear end to the old T connector. The fittings are different on the old and new T connector for the rear brakes. I still have not hooked up the e brake cables but all that needs to be done is to lengthen the cable already on the car to go further back to meet the new 4th gen cables.
Old Feb 22, 2007 | 07:11 AM
LT4Hawk9's Avatar
Engine: 350ci LT4
Axle/Gears: 3.42:1
That's exactly what I needed to know. Thanks!
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
