Chevy Transmissions
Old Feb 27, 2007 | 01:48 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Chevy Transmissions
There are a couple of 94-96 wrecked chevy pick up trucks with good transmissions on it, what year would you guys recommend to pull off and put it on my IROC?
Old Feb 28, 2007 | 05:19 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
you might get lucky and find a non-electronic tranny in one of the '94s, but for the most part chevy had electronically controlled trannys by '94. any of the 2wd versions would fit, but you need some way to control it since the iroc's ecm has no way to do so.
Old Feb 28, 2007 | 12:27 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
92 started VSS
by 94 theyre E model
Old Feb 28, 2007 | 12:46 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I know TCI and I am sure several other companies make a stand alone control module to retrofit older cars with the electronicly controlled trans into a non computer controlled car.
http://www.tciauto.com/Products/Electronics/
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
