play in rear
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
play in rear
well i started noticing that when going about 30 mph if i jerk the wheel side to side the back end shimmys not up and down but side to side..... when car is parked if i push back and forth on the back end i get the shimmy and some unfriedly noises... its seems as tho my drive shaft has some play in it... any ides what it could be?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if the rear is moving side to side, check and see if your panhardbar is attached, or broken, or missing.
Car: 86 Trans Am
it will cause undue stress on the lower control arms and mounts, as the rear moves about, this can damage more of the car. get a new one as fast as possible if it is broken or missing and try to drive as little as possible
BlackphantomZ28
Aug 22, 2015 01:00 PM
