Using a used ring and pinion bad idea?
Old Mar 5, 2007 | 01:35 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I have a set of 3:42s from a 95 Camaro. The guy said it had 18k on it when he pulled them for 4:10s. He said he didn't abuse them. I am upgrading the rear with superior axles, auburn posi and a TA rear end cover. The usual strength mods. I am taking out a set of whining 4:10s to rebuild it with these goodies.
My brother (mechanic) looked at these gears and said they look to be in perfect shape. I am still leaning on buying a new set just for peace of mind. Not sure.
If I do, whats brand would you recommend? I haven't had any luck with Richmonds.
Also, if any chance someone in the southern WV area reads this, where is a good gear install shop near Charleston or Huntington? I'd have my brother install them but he's 400 miles away.
Old Mar 5, 2007 | 02:53 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
well if you trust the guy's word of mouth, then go for it.. i used a set of 3.73 and a posi from a camaro that went into a ditch.. worked good but i didnt have very good results at the strip.. i shattered the posi from wheelhop..
Old Mar 5, 2007 | 04:22 AM
EvilCartman's Avatar
Car: '82 Z28
Run the used ones if they look how your brother said they look, 18k miles is nothing. The 4.56 gears in my 9 inch are used with unknown history. Zero problems with them so far.
Old Mar 5, 2007 | 09:18 AM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
used gears are ok, just be sure to check the teeth, which it sounds like your bro said is ok, dont get a used posi unit thought, id recomend a detroit true trac for a LSD, its a non cluch style one
Old Mar 5, 2007 | 11:15 AM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
The posi I got is a Auborn unit with 9k on it from a 4th gen. The guy said they simply upgraded to an Eaton so I hope it's good. This is the last 7.5 rear I'll ever put together though. I am going to have a 9" fund set aside to save up for one.
I'll see if I can post a pic of the gears later tonight.
Old Mar 5, 2007 | 02:19 PM
5678TA's Avatar
Car: 1984 Trans Am
TRUE TRAC!!!! i have one in my 9" and LOVE it
hectre13
Dec 11, 2023 08:14 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
hectre13
Aug 26, 2015 08:17 AM
89fast5oh
Aug 24, 2015 08:14 AM
