car is hard to stop?
Old Mar 14, 2007 | 04:05 PM
loudmouthz28's Avatar
I just bought an 89 formula and whenever the car is in drive it wants to take off unless you literaly stand on the brakes. I've driven other automatics before but I've never seen one that pulls as hard as mine does wothout even touching the accelerator. I can let off the gas when driving and the car will pretty much maintain the speed I thought maybe its a converter problem or something? Any help is greatly appreciated.
Old Mar 14, 2007 | 04:59 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
What does the tachometer read with the engine running in Park?
Old Mar 14, 2007 | 05:14 PM
800 or so, 1200 when in neutral
Old Mar 14, 2007 | 06:29 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
too fast
slow it down to around 700 or 750 in park/neutral
if the pedal is very hard and you have to standon it with both feet to stop it then the booster is junk
good luck
Old Mar 14, 2007 | 08:28 PM
the pedal isn't hard, it just requires alot of force to stop the car. If I set the idle to 700 in park that would put it at 400 when in drive, wouldn't that be too low?
EDIT: just checked it's actually 650-700 when in drive & 1100 when in park
Old Mar 14, 2007 | 08:47 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
My car has always done that too, I suspect the converter was made tight this way for fuel economy in city driving or something. I just had to learn to live with it, hasn't caused any problems otherwise. Chirps the tires going into second gear with just a little throttle too.
Old Mar 14, 2007 | 09:04 PM
thats wierd, I guess it wont hurt anything, it's just kind of a pain.
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
