Kickdown Valve?
Old Mar 23, 2007 | 11:53 PM
Black85Z28's Avatar
Car: 1985 Z28
Transmission: 700-R4
Axle/Gears: 3.08
Kickdown Valve?
I heard if I change out the carb on my 85 Z28, the kickdown "valve" wont function right until I do something with it...
Anyone know what this person was trying to say?
For one, they did say it has a kickdown valve and not a cable...
Old Mar 24, 2007 | 11:23 PM
Black85Z28's Avatar
Car: 1985 Z28
Axle/Gears: 3.08
Re: Kickdown Valve?
Can anyone shed some light on this topic?
Old Mar 25, 2007 | 07:41 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Kickdown Valve?
they must have gotten mixed up. it is the cable or cable bracket you need to change to keep the cable geometry correct. for example....holley and edlebrock carbs use a special bracket for the cable.
Old Mar 27, 2007 | 11:24 PM
Black85Z28's Avatar
Car: 1985 Z28
Axle/Gears: 3.08
Re: Kickdown Valve?
Haha, Do they have this bracket available or do only certain companies make it?
Thanks man, Joe
**EDIT**
Nvm, I found some stuff on their site http://www.holley.com/20-95.asp
http://www.holley.com/data/Products/.../199R10137.pdf
Old Mar 29, 2007 | 10:47 AM
Shagwell's Avatar
Car: projects.......
Re: Kickdown Valve?
Holley & Edelbrock both have brackets for their carbs to work in conjunction with a 700r4 detent cable.
- on 700r4, it is not a "kickdown cable". It is a detent cable. It controls the TV valve, which controls the line pressure inside tha trans, which translates to varied pressure behind the governor, which controls up/down shifts. If it is not properly set, it can cause the destruction of your transmission. - make sure you get the proper bracketry for the cable mount as well as the proper bracket to attach the end of the cable to the carb linkage. Then be sure to properly adjust it.(instructions of which have been posted many times, search it out)
Old Mar 29, 2007 | 11:49 AM
Black85Z28's Avatar
Car: 1985 Z28
Axle/Gears: 3.08
Re: Kickdown Valve?
Great man, thanks for the information
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
