Stuck U-Joint during driveshaft removal
Old Mar 27, 2007 | 12:10 AM
mrogers's Avatar
Car: '87 Camaro
Engine: 4.3L V6
Axle/Gears: 3.08
I tried removeing the driveshaft, the straps came off easy but the u joint is lightly rusted in. I tapped it lightly with a hammer but it's stuck. The joint is still good so I'd rather not destroy it. Any suggestions?
Old Mar 29, 2007 | 12:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Stuck U-Joint during driveshaft removal
This is the rear U-joint? Why do you want to remove it?
If it's stuck and won't move, hit it with some grease if it's greaseable, and spray it with WD-40 or something and tap it with a hammer again.
If you're actually trying to remove it, you'll need to use a torch to get rid of the nylon locking ring. But that means you're replacing it with a new one so...
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Nick McCardle
Sep 10, 2015 08:36 PM
