Axle Questions ? ?
Old Mar 27, 2007 | 04:06 PM
novatuc's Avatar
Car: 1984 Trans Am
Axle Questions ? ?
Well folks did the complete rear drivetrain rebuild including aluminum driveshaft and I'm still shakin'. The only thing I haven't changed are the axles themselves and they measure out to be good but who knows. Two questions: Has anyone ever cured a vibration problem by changing to aftermarket axles? Moser axles seem to be the easiest for me to pickup from a place like Summit. Do the normal Moser's work with stock bearings and seals or are they a different size? Anybody want to chime in with a different axle or supplier, feel free.
Old Mar 27, 2007 | 04:49 PM
Re: Axle Questions ? ?
Yes, you could accidentally fix a vibe by changing the axles, if one of them is causing it by being bent.
First thing to do when troubleshooting a vibe, is to figure out if it's at wheel speed, drive shaft speed, or engine speed. Which is yours?
Old Mar 27, 2007 | 07:03 PM
novatuc's Avatar
Car: 1984 Trans Am
Problem is related to road speed. Don't wanna go there here, got a huge post going elsewhere. Axles are all that's left. I noticed the seals, which are only 4 days old are weeping a bit, so it might be a good reason to change the axles. Plus they've got about 120,000 miles on them and I don't think the previous owner was gentle on the poor old open diff. Other question is still open. Do the Moser's or any aftermarket axle run with stock bearings?
Old Mar 27, 2007 | 07:26 PM
yes
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Oct 7, 2015 08:35 PM
downsouthboy
Aug 29, 2015 11:29 AM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
