TH400 trans question
I just had a fresh th400 droped off and I cant figure out where this ring goes. I need to get this trans in today. Can someone let me know?
[IMG]file:///C:/Documents%20and%20Settings/Randy/Desktop/ring.jpg[/IMG]
Last edited by quadrojunk; Apr 2, 2007 at 08:11 AM. Reason: pic didnt load.... the ring clips to its self
Re: TH400 trans question
Can't see images stored on your local PC.
Use the "attachments" button down at the bottom.
If it is aluminum, it looks like the low/reverse accumulator ring that is under the 6 bolt steel cover that holds the low/reverse band apply piston. If it is cast iron, then it is the stator or center support ring.
I dont know what that piece was but I put the trans in and when I pulled it down into gear it made a terrable noise, didnt go into gear and I shut it off right away.
I am taking it back out and giving it back to the guy who built it. Let yall know what happens next.
I am taking it back out and giving it back to the guy who built it. Let yall know what happens next. Thread
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
