why did my 87 formula 350 come with a 9bolt?
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i was under the car a week and a half ago and i always assumed that i had a 10bolt bc my car was a stock 350TPI and they only used the strongest stuff. but low and behold i counted the bolts on my rear and its a 9 bolt damn! ive heard there isnt many things out there for these rears, but eventually gona put in a 500hp 383 so im prob gona want to put in a auburn pro limited slip and moser axels.
why did my 350tpi come with a 9 bolt? which was stronger? and are there parts for my 9 bolt or
should i just look for a 10bolt?
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
Re: why did my 87 formula 350 come with a 9bolt?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The 9 bolt is stronger than the 10 bolt.
Car: 87 TA clone
yea thats what i heard but the 9 bolts are hard to find parts for it. can a 9 bolt be built to live behind a 450-500hp 383? please say yessss
moser axles, some kind of good posi, and raytech instilation kits and maybe 3.42 gears.
Engine: 383 Carb
Transmission: 4L60
How long it lives depends on how badly you abuse it.
Your worst problem will be trying to find a "good" posi unit for a 9 bolt. As far as I know, nobody offers new replacement units, and the original ones seem to burn out really easy. There is a tech article on the site here that tells you how to shim the posi so it grabs good again. I'm also not sure if Moser or anyone else offers replacement 9 bolt axles either. If you're seriously going to be putting roughly 500 HP to the rear wheels, your only sensible choice is an aftermarket 9 inch or 12 bolt from Moser that's custom built for our cars. They run about $2K, but any 9 bolt or 10 bolt factory rear is going to be living on borrowed time behind a stout motor like the one you're suggesting. It sucks to have to pay that much for a rearend, but if you put one of those under your car, you can beat on it all you want without worrying about breaking the rear. I have a factory 12 bolt under my 69 Camaro that I've hammered on for 20 years now, and it's never broken anything. I've grenaded several Muncie 4 speeds over the years, but that 12 bolt just keeps on truckin!
