700r4 problems
Old Apr 4, 2007 | 08:32 PM
Matt_Critt's Avatar
Car: 1986 Camaro Iroc
700r4 problems
I have a '86 Iroc with a 305 and 700r4. About 2 years ago the stock 700r4 went out on my brother, he replaced it with a used 700r4 out of a caprice (uknown year). evedently everything was similar, since everything bolted up correctly (except the speedo isn even close). He drove maybe 2 weeks before it overheated and he parked it. I get it running last week and take it out, the transmissions was slipping, but it had all the gears. After I got off of work, it now ony has 1 and 2. I noticed the tranny fluid was extremely low, so i added some (how much does the tranny hold ??) tranny fluid and some transmission leak stopper. I take it out on the highway and it doesnt seem to slip much in 1,2 anymore, but D and OD are completly out of it.
is there anything that is causing it, or is my tranny smoked??
Old Apr 4, 2007 | 08:46 PM
Matt_Critt's Avatar
Re: 700r4 problems
ok, i believe the tranny was out of a '83 Caprice
Old Apr 4, 2007 | 09:30 PM
408 84 z28's Avatar
Car: 84 camaro 74,000 miles
Engine: 408
Axle/Gears: 4.10
Re: 700r4 problems
The tranny holds 11 quarts.Maybe smoked the forward cluthes.If the cable is not adjusted right won't have enough line pressure.If it shifts late TROTTLE
VALVE might be suck.
Old Apr 4, 2007 | 10:18 PM
Matt_Critt's Avatar
Re: 700r4 problems
do overhault kits come with the parts to fix the burnt out clutches, or do i have to buy them seperatly
Old Apr 4, 2007 | 11:34 PM
Pro Built Automatics's Avatar
Re: 700r4 problems
The 3-4 clutches are gone, (common). The rebuild kit that I carry (it is very complete) has all the clutches, steels and everything else that is needed to do this correctly. Let me know if I can be of help? Dana
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
