gear in tranny change for rear
Old Apr 6, 2007 | 11:00 AM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
ok im wondering how hard this is to do. i keep saying i want lower gears from my 2.73s and everyone is saying id need to swap a gear in the transmission to correct the speedometer. what is this gear called? and how exactly do you go about changing it?
Old Apr 6, 2007 | 11:55 AM
rn2686's Avatar
Car: 92 Camaro RS
Engine: Secret
Transmission: Secret
Axle/Gears: Secret
Re: gear in tranny change for rear
It's the speedometer gear. You should be able to find a ton of info on here. Someone else should chime in though, as I have no experience changing one of these.
Old Apr 6, 2007 | 12:01 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Pretty simple actually. The driver and driven gears will probably need changed. The driver is on the tailshaft, just remove the tail shaft housing, a bit of fluid will leak out, no major parts to fool with. The gear just slides on and off, a clip holds it on. The driven gear is in the plug that goes in the side of the tailshaft, easy swap.
Old Apr 6, 2007 | 01:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The speedo gears can be acquired from www.700r4.com - they have a conversion calculator online to help you choose the right gears.
Old Apr 6, 2007 | 02:28 PM
Engine: LO3
you have to change the gear on the inside you cant just change the outter gear so i dont have to take the tranny apart a bit not the kinda thing i want to do. unless i really have to. how is the one in the side? i dont get how you would take that one out.
Old Apr 6, 2007 | 05:45 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
it slides out with the retainer deal that the cable threads onto, or that the VSS connects to, whichever you have
a little bolt holds it in place
cant miss it
Old Apr 7, 2007 | 10:48 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Oops. Is this a gear drive speedometer or an electric? Whole different deal without the cable. Some cars have a conversion module on the side of the ECM that drives the speedometer that would have to be changed.
Old Apr 7, 2007 | 02:31 PM
Engine: LO3
im not sure i have an 1989 lo3 couldnt tell ya
Old Apr 7, 2007 | 10:47 PM
Car: 1992 RS
Engine: Carbed 350
It's really not that big of a deal to change - you don't take the tranny apart, just remove the tailhousing - there are 4 bolts that hold it on. You'll need to remove the driveshaft (take 4 bolts out of pinion, and pull it out of tranny), then take 4 bolts out of tailhousing and remove it, and there's the gear, depress clip, slide it off, replace with new, and replace tailhousing and drive shaft. Then change the gear in the speedo housing and done.
hectre13
Dec 11, 2023 08:14 AM
camaro11j
Sep 19, 2018 08:49 AM
hectre13
Aug 26, 2015 08:17 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
